Results 1 to 4 of 4
Thread: it's alive!
    May 2011
    Smile it's alive!
    Finally after months of work my router is up and running. I figured I would post a few pics. I will list the specs below. So far it works great almost no backlash. Seems very rigid. Best of all I did all of the machining here at the house with my manual mill and lathe.
    Frame solid 3/4" thick 6061 aluminum bar stock.
    3/4" MDF bed supported in the center by frame.
    15MM linear guides on X and Z
    20MM linear guides on Y
    16MM ball screws on all axis bearings on both ends.
    Helical couplers
    Gecko 540 stepper driver
    48V power supply
    380oz steppers
    Mach 3 control
    Travels 26" x 46" x 6"
    Apr 2003
    Congratulations, looks like a great machine!
    Registered DonFrambach's Avatar
    Nov 2006
    Very nice! What is that protruding from your router?
    May 2011
    I had an indicator in the spindle doing some backlash checks.
  1. its alive
    By woffler in forum Dolphin CADCAM
    Last Post: 02-18-2008, 01:43 PM
  2. It's ALIVE!..... uh almost. (x3)
    By Deviant in forum Benchtop Machines
    Last Post: 01-13-2008, 02:57 PM
  3. Mostly ALIVE
    By Smitty911 in forum Benchtop Machines
    Last Post: 11-15-2007, 07:24 PM
  4. It's Alive!!!!
    By chevdrgtrk in forum Bridgeport and Hardinge Mills
    Last Post: 10-11-2007, 02:51 PM
  5. Its Alive
    By debogus in forum DIY CNC Router Table Machines
    Last Post: 03-09-2005, 09:05 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
