Results 1 to 3 of 3
Thread: Steps per rev?
    May 2011
    Smile Steps per rev?
    Ok i'm confused. Setting up Mach 3 to use on 6MM pitch ball scews direct drive stepper motors with Gecko 540 10 micro step drive. Do I need to change setup units to MM or can I figure this in inch? I know the calculation for revs per MM would be .166. In inch that would be 4.233 revs per inch. So what would I enter in the motor tuning section for steps per? I would really rather use inch units if possible. According to the mach 3 manual it takes 2000 steps from Mach 3 to turn a stepper one rev using a 10 micro step driver. So am I correct that for inch I would multiply 2000 by 4.233? That would be 8466. Is that the correct steps per or am I way off?
    Thanks,
    Brad
    Mar 2003
    Shelby Twp, MI....USA
    Yes, 8466.6666666 is what you should enter for steps/unit for inches.
    May 2011
    Smile
    Thanks, I was hoping I was on the right track.
  1. What's the steps ?
    By SScnc in forum ArtCam Pro
    Last Post: 12-10-2010, 11:21 AM
  2. 51,200 steps?
    By dondeaida in forum Stepper Motors and Drives
    Last Post: 05-26-2007, 07:15 AM
  3. Steps
    By Cartierusm in forum General CAM Discussion
    Last Post: 04-24-2007, 01:33 PM
  4. Full Steps -vs- Micro Steps
    By DJB282000 in forum General Electronics Discussion
    Last Post: 12-29-2005, 12:25 AM
  5. 125,000 steps per second
    By smarbaga in forum Stepper Motors and Drives
    Last Post: 07-30-2005, 10:47 AM
