Results 1 to 4 of 4
Thread: large 3 axis machine
    Mar 2009
    israel
    Hi
    I'd like some feedback on a design now underway:
    its a 3 axis machine based on a rectangular box frame
    moving head, workpiece is stationary
    x axis - 2meters - rack and pinion
    y axis - 75cm - twin ballscrew
    z axis - 50cm - single or twin ballscrew
    Will nema 34 motors need to be geared down? We dont care about speed
    but would like 0.1mm accuracy
    Will cutting soft metal be possible on such a machine?
    TIA Jeremy
    Attached Thumbnails Attached Thumbnails large 3 axis machine-cnc_draft_based_table.jpg
    May 2005
    canada
    Quote Originally Posted by rutman View Post
    The most common design is a single y screw placed midway between the slides.
    Is your design more like a mechmate/shopbot ?
    MechMate CNC Router - Build your own with our detailed plans
    hard to imagine wanting twin ballscrews here
    That's a lot of Z height, does your work need that kind of clearance ?
    Anyone who says "It only goes together one way" has no imagination.
    Mar 2009
    israel
    Quote Originally Posted by cyclestart View Post
    Ok we will prob. do that instead
    MechMate CNC Router - Build your own with our detailed plans .
    Yes that's the idea just with a much larger Z throw.
    hard to imagine wanting twin ballscrews here.
    For this I was thinking the large z throw would necessitate sturdier construction - tho' we have a 50cm long ~3cm diameter lead screw so maybe that's enough with a single screw. I suppose the slides are what give most of the suport in any case and the screw is simply for downward thrust thus two are indeed unecessary.
    Ideally we'd like to do things like kayaks, jet cowlings and others so we're going for a lot of Z - my build partner wanted to move the entire y-z setup with rack/pinion and tool in order to change the z distance if wanted, while I favor moving the workpiece by means of an adjustable floor - he beleives that an adjustable y-z is necessary since e.g. the rails will be going out of alignment and need periodic adjustment. I personally was thinking if we fix those in palce insofar as possible by welds, then scallop or otherwise work the rails to reach parallelism, then they will not likely go out of true.
    Any thoughts on this?
    May 2005
    canada
    Yes. In a perfect world the sliding components would have zero play, the pieces spanning the slides would have infinite stiffness, or we could have very wide spacing between the sliding components along a rail. In my opinion dual drives are a compromise, but when the span gets wide it's a compromise that makes sense. Counting on a centrally placed ball nut to prevent racking is a bad idea, that's the job of the other components. The mechmate design seems to rule out a central y screw ? With decent components racking would be minimal over that narrow span.
    I've operated a machine that could raise/lower the bridge but it was a very heavy bridge mill. I'm not sure what is the best approach for a lighter machine.
  1. Parker HZR100 for large scale machine Z axis?
    By kentster in forum DIY CNC Router Table Machines
    Last Post: 08-03-2011, 04:58 PM
  2. RFQ: Large EPS Molds. 5-axis or 3+2
    By Hampton77 in forum RFQ (Request for Quote)
    Last Post: 07-27-2011, 02:54 PM
  3. large DiY 3-axis. need guidance
    By Loz in forum DIY CNC Router Table Machines
    Last Post: 03-23-2010, 05:23 AM
  4. Machine Large Alu Plate for CNC router
    By wfung in forum General Metalwork Discussion
    Last Post: 12-11-2007, 05:07 PM
  5. Large format plotter/drafting machine
    By thuffner3 in forum DIY CNC Router Table Machines
    Last Post: 01-17-2004, 12:52 PM
