Results 1 to 4 of 4
Thread: help stepper motor
    Jun 2011
    scotland
    help stepper motor
    hi can anyone help me , wot size (NM) would you need to cutt 18mm birch ply?
    any help would be grate
    Sep 2010
    I have just finished a router using 425 oz motors and I have no trouble cutting 3/4" birch ply. I am using a Porter Cable 690 router.
    Quote Originally Posted by mrlee1982 View Post
    Mar 2006
    NC, USA
    You have to take more than just the motor size into consideration... the spindle, the integrity of the machine, also the depth of cut per pass, desired finish. There's also this thing called chip loading that I understand the basics of, I think masters of machining have to know this to maximise job efficiency, I know you don't want to burn up bits or material and I look for signs of both when I tweak speeds.
    If you want to cut 3/4 birch in one pass you'll need a pretty good setup.
    Sep 2010
    Quote Originally Posted by CurtisU View Post
    There are some very good points here. For clarification I will elaborate on my response.
    I have just finished building a CNC router that I use to cut plywood, plastic, MDF and aluminum. It is constructed out of 8020 aluminum extrusions and some parts made of 1/2" aluminum plate. The drive system is R&P (CNC router parts), the linear motion is V rails and I am using a Porter Cable 690 router.
    The machine will rapid as fast as 750 ipm, but I have my rapids set at 500 ipm because it seems to fit best with the size of the machine.
    When I cut 3/4" birch plywood I use a 2 flute, 1/4" carbide up-cut spiral endmill from Amana Tool. I am currently running the endmill at 27500 RPM, taking passes at 1/4" DOC and cutting at 120 ipm.
    I am sure that I could push the endmill faster, but I need to perform some more testing. I use a simple method of testing my cutters. I program a zig-zag pattern with legs 2" to 4" long (depending on the material). Each leg of the zig-zag is cut at a different speed. For plywood I would probably start with 30 ipm, increasing the speed 30 ipm for each leg. That way I would end up with cuts at 30,60,90,120,150... etc. I simply watch the machine and the cuts. Once the cuts start to degrade in quality, or the machine starts to indicate that it is being over driven, I stop the test and inspect the cuts. It is usually fairly obvious what the best cut speeds are.
    I hope this helps.
  1. Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 06:50 AM
  2. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors and Drives
    Last Post: 07-25-2010, 03:19 AM
  3. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum Product and Manufacturer Announcements
    Last Post: 06-07-2010, 04:59 AM
  4. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors and Drives
    Last Post: 10-16-2007, 05:56 PM
  5. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors and Drives
    Last Post: 01-03-2005, 06:05 PM
