Results 1 to 1 of 1
Thread: 13ft x 6ft cantilever router
    Jan 2009
    us
    I've got a set of star 13' rails mounted on a fixture from hell 2.25" x 2.25" x .250 wall square tube (about 1200lbs). Also a set of 6' thk's. mounted to a 4" x 6" x .250 tube. If supported well enough, can I run x axis supported only from one end, without to much deflection. Running two bearings per rail on all 4 rails. Star bearings are 2.25" x 4" on 1.5" rail. Half this size on thk's. X axis will be about 100lbs for just the tube and rails. Not counting the spindle. Also running timming belt. What should I run for stepper, or servo. Thanks
    One more revise. I want to cut 3/4" plywood.
    Pic 1 rails and fixture
    Pic 2 pick and place I robbed the x from
    pic 3 fixture from side
    Pic 4 orange fixture I will mount x on
    Attached Thumbnails Attached Thumbnails 13ft x 6ft cantilever router-cnc_004.jpg   13ft x 6ft cantilever router-cnc_008.jpg   13ft x 6ft cantilever router-cnc_003.jpg   13ft x 6ft cantilever router-cnc_014.jpg
  1. Newbie- Buying a new 48x48 Art-Router 4 Axis CNC Router
    By Stoch in forum Open Source CNC Machine Designs
    Last Post: 12-17-2010, 07:08 AM
  2. Need Help!- with a Precix Table Router with Perske router
    By SignShop Grunt in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-08-2010, 05:08 PM
  3. I-Beam Cantilever Weight Load Capacity ?
    By Dan150 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-27-2008, 08:29 AM
  4. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 04:33 PM
  5. Surfcam PP for Isel router / Precix router
    By IvanTochev in forum Post Processor Files
    Last Post: 05-12-2004, 01:27 PM
