Results 1 to 2 of 2
Thread: wire management idea
    Jan 2005
    I am looking for an alternative to the wire chain that is so expensive
    I have an idea to use 1-1/2 aluminum square tubing 1/6" wall as a conduit the top one for dc and the bottom one for ac the router plug will fit through the 1-1/2 " square tubing. I have shown it fully extended but you can never let it go that far as it will lock in position, you can use 1/4" button head screws with lock nuts ( the head inside and the nuts outside, I have shown one plate but i think the square tubing needs to be sanwinched between two,
    Attached Thumbnails Attached Thumbnails wire management idea-wire_managemant_model_1_.pdf
    Registered CNC Lurker's Avatar
    May 2009
    That's basically how Lionclaw did his arm on the Y-axis. He posted his plans on here and you can build that arm out of MDF or plywood. I would think putting a plastic washer between the "hinged" parts would reduce friction between the moving parts.
    Attached is a screenshot of it.
    Attached Thumbnails Attached Thumbnails wire management idea-lionclaw_arm.jpg
    http://paul-flores.com/
  1. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum General Waterjet
    Last Post: 01-26-2011, 04:47 AM
  2. Mitsubishi wire type setting for zinc coated wire
    Last Post: 01-25-2011, 07:49 AM
  3. Running stepper motor wire with router wire?
    By basskitcase in forum DIY CNC Router Table Machines
    Last Post: 02-19-2010, 11:18 AM
  4. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 05:34 PM
  5. New Twist on Wire Management
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 04-30-2003, 04:34 PM
