Results 1 to 9 of 9
Thread: FLA-200 Linear Bearings Pulling my hair out!
    Nov 2009
    I am trying to get my Y gantry Aquare on the X rails of my fla-200. I must not be going about it in the proper manner. Every time I think I have it squared up, one side or the other is sloppy and out of square. Anyone done this successfully have any suggestions on how to do it?
    Any and all comments would be appreciated.
    David
    Sep 2009
    I loosened the carriages that ride the x rails a bit...that is, the bolts that attach the carriages to the lower gantry. Then I backed up the gantry under power until it was at the x=o end of the table (I placed two equal sized blocks of MDF between the legs and where the gantry would hit). So with the gantry jammed against the MDF blocks, I figured the gantry was as square to the x axis as the table was square. Then I tightened the x axis carriages to the gantry. If you find you cannot get quite enough adjustment that way, you may have to loosen the fasteners holding your gantry together, and go through the same sequence.
    Angie
    Nov 2009
    Still with the bearings
    Did you get all of your bearings rolling at the same time. I can get either the top ones or the bottom ones, but not all 4 of them at the same time. I have figured out how to get them fairly square, but I am feeling a lot of resistance when I move the gantry back and forth. Are the adjustable one on the top or the bottom?
    David
    Nate Feel free to chime in here at any time!
    Sep 2009
    My adjustable bearings are on the top. I also find it difficult to keep all the bearings in contact with the 1/4 steel ways.
    Registered Drools's Avatar
    Feb 2009
    My adjusters are on the top as well. All my bearings move when the axis moves, I check every week or so.
    Nov 2009
    Bearings tight, no slop
    But, if it wouldn't be too much trouble, could you take a snapshot of your Z axis in reference to your table and Y gantry. I am not sure how to position it.
    David
    Mar 2010
    I have an FLA-300, and had a real hard time with this.
    What worked for me was doing the best job I could getting the mechanics square, and then using Mach to finish the job. Your 200 has dual Y drives, right? Put separate homing switches on each side, and adjust them to get the X square to Y (find the corner points and measure the diagonals).
    Nov 2009
    No more hair pulling
    It seems that Harbor Freight has these wonderfully long squeeze clamps, worked perfectly. All bearings are rolling, no play in any of the Axixs, just ran the maiden cut, and it went perfectly
    Apr 2011
    please give pic or link to them
    Quote Originally Posted by crash5050 View Post
    1. Pulling my hair out trying to find components for a jig; adjustment screw arrangement
      By nadsab in forum Work Fixtures and Hold-Down Solutions
      Last Post: 03-16-2011, 03:25 AM
    2. Need Help!- Pulling hair out! Problem with material webbing.
      By xncrman in forum Vacuum forming, Thermoforming Etc
      Last Post: 01-29-2011, 10:58 AM
    3. pulling hair out
      By radioman in forum DIY CNC Router Table Machines
      Last Post: 01-05-2010, 04:16 PM
    4. Need Help!- HAAS MINI MILL Question (I'm pulling my hair out)
      By Powder_Keg in forum Haas Mills
      Last Post: 09-19-2008, 10:09 AM
    5. 203V Pulling my hair out!!
      By WilliamD in forum Gecko Drives
      Last Post: 04-18-2008, 02:09 AM
