Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Is this motor usable
    Mar 2009
    canada
    Hi I have acquired 2 of these motors and I am trying determine if I can use them for my cnc machine. They are from an industrial manufacturing plant as surplus, if anyone can provide any info on them it would be great. I searched ABB Robotics but could find nothing on these
    they are ABB Robotics
    Type: PS 60/4-50-P-LSS-3985
    Art.no: 3 HAB 3125-1/8
    thanks
    archer3d
    Attached Thumbnails Attached Thumbnails Is this motor usable-img_7309.jpg   Is this motor usable-img_7310.jpg   Is this motor usable-img_7314.jpg   Is this motor usable-img_7313.jpg
    Sep 2010
    Since nobody else has chimed in...
    I am not an expert and since you are asking for advise, you probably are not either unless you are just playing stump the audience.
    If you are playing around with it and tinkering, they are probably fine. If you are going to try to build a day to day system that you are going to depend on, I wouldn't mess with them. I would focus on readily available motors (and any other component for that matter) that are known, documented, and most importantly replaceable. If you are just fiddling around with a system, being down and having to stop, rewire, make new motor mounts, and recalibrate a machine, it is no big deal. You really don't want to have to stop and figure out a new motor in the middle of a job with deadlines breathing down your neck and your income relying on it being up and running.
    My uncensored views and CNC Router planning: http://reinventingcnc.blogspot.com/
    Registered judleroy's Avatar
    Dec 2006
    You can also look at this Dynomotion | Motion Control Boards website. There system can run stepper motors, brush dc motors, and brushless motors and all closed loop. The reason I say this is if you have a motor go bad you can replace it with about any other motor you find to replace it without the trouble of buying new controllers or spending alot of time setting them up. Good luck.
    Judleroy
    Dec 2003
    You would need to do quite a bit of reverse engineering to get the specs, If they are off a robot, they are most likely to have absolute encoders, if they are fitted with actual hall effect devices for commutation, they may be able to be used with a BLDC drive?
    Again, without specs, reverse engineering is needed.
    Mar 2009
    canada
    Thank you all for the responses. I have little information on them they are a Dc servo motor and they were running at 347vdc. The part opposite to the drive side is a brake
    archer3d
    Dec 2003
    I believe you mean DCBL they do not appear to be DC brushed?
    Mar 2009
    canada
    Quote Originally Posted by Al_The_Man View Post
    As was stated in an earlier post, quite correctly I am not an expert in any way on these, what is DCBL ? and how would i check for that?
    thanks
    archer3d
    Dec 2003
    The absence of carbon brushes is usually the first give away, the power is to a 3 wire stator on a BLDC (Brushless D.C.) instead of 2 wire brushed armature in DC brushed.
    Mar 2009
    canada
    ok thanks I will crack the motor open and see whats inside. I will post some pics when its done
    archer3d
    Mar 2009
    canada
    That was relatively easy and painless here are some pics there are no carbon brushes i can see
    archer3d
    Attached Thumbnails Attached Thumbnails Is this motor usable-img_7315.jpg   Is this motor usable-img_7317.jpg   Is this motor usable-img_7318.jpg   Is this motor usable-img_7319.jpg
    Dec 2003
    DCBL = wound stator. PM rotor.
    DC Brushed = wound rotor. PM stator.
    Also looks like a very old type of motor. Looks like resolver and you may even have discrete Hall effect sensors for commutation?
    Mar 2009
    canada
    I am wondering if these are rated for 347dc power what will happen if I try to run them at a much lower voltage say 48vdc
    archer3d
  • Page 1 of 2 12 LastLast
    1. Newbie- labvolt usable?
      By tey1967 in forum Want To Buy...Need help!
      Last Post: 09-18-2008, 10:02 PM
    2. Is this motor usable?
      By dex918 in forum Stepper Motors and Drives
      Last Post: 09-27-2007, 02:08 PM
    3. Usable Laptop?
      By Oldmanandhistoy in forum Computers and Networking
      Last Post: 03-08-2007, 10:02 AM
    4. Nippon Pulse Motor PJ55 (PJ55B1-28B), Info/Usable?
      By madcow in forum Stepper Motors and Drives
      Last Post: 07-31-2006, 04:58 PM
    5. Is it usable
      By 2muchstuff in forum Open Source Controller Boards
      Last Post: 04-20-2005, 02:50 AM
