Results 1 to 3 of 3
Thread: Just starting
    Jan 2008
    Just starting
    Hello, longtime lurker here.
    Finally starting to collect pieces for my CNC project. I have the base which is put together from a Rousseauco workbench system 44"x64". One 44x44 section and one 20x20 section and 3/4" Industrial MDF. At one end of the workbench I plan on having the dust collector motor (HarborFreight 2 HP) inside a sound proofed enclosure. This area is 44x20.
    The cutting area of the machine is 48" x 48". I only see cutting wood or plastic on this, no metals. Subject to change though. Signs, plaques, cabinets, mantels, patterns,carpenters tool boxes, etc.
    I have an old Sears Router Crafter that I will use for a 4th axis once I get a motor hooked to it.
    Electronics will be steppers, around 400oz. Not sure on the drivers yet, more than likely GECKO's. I have a Makita 2 1/4hp variable speed router, that's been collecting dust, for the spindle. trying to find a quick chuck system for it.
    I'm very set on FineLineAutomation's Rack & Pinnion system.
    Top end of the system will be 8020 construction. Z axis TBD, X axis 3030, Y axis ? With a 6" cut depth.
    Y axis will also be dual driven.
    A question I have is, would 1530 that is bolted down be stiff enough for the Y axis or should I go with 3030?
    I receive $500 a month for being a moving target in my earlier years. Budget for my project is $500 a month, already spent for January. February's is burning a hole in my pocket, researching the 8020 stuff.
    Don
    Mar 2010
    I have the FLA 4x4 and it uses 3030.
    You probably mean you want to use the cncrouterparts R&P system, which Fineline buys from them.
    I very much like the FLA-300 4 x 4 design. The fundamental idea I like is that the X gantry is a single 3030 beam, directly tied to the carriages. The bed is hung below the Y rails. This means that the gantry is not suspended up from the Y rails by some structure, and it means that the gantry is just the beam, with it's R&P rail/rack.
    Jan 2008
    You are correct on the cncrouterparts, I have so many things linked they start to blend together.
    The FLA-300 is one I like. Thanks for your input.
  1. Newbie- starting out
    By pitchbrown in forum Machine Created Art
    Last Post: 09-04-2012, 12:52 PM
  2. Just starting out
    By Larry Myers in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 09-20-2009, 05:08 PM
  3. Need Help!- STarting NEw project - Need Serious Help to Understand PArts before starting
    By osix in forum DIY CNC Router Table Machines
    Last Post: 06-30-2008, 04:54 PM
  4. starting out
    By onya in forum Australia, New Zealand Club house
    Last Post: 12-20-2007, 03:57 AM
  5. Just starting out
    By BawFlinger in forum OneCNC
    Last Post: 10-18-2006, 04:13 AM
