Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Second MDF machine build. Free METRIC plans!
    Aug 2009
    Finland
    Exclamation Second MDF machine build. Free METRIC plans!
    I don't see much love for the MDF machines here nowadays but here is my second machine that I built last fall. The main structures are made of 19mm & 12mm mdf strips that I ordered pre-cut to the correct width. Z and Y axis carriage & some other smaller parts are made from 15mm baltic birch plywood, cut with my first diy machine.
    I used about 50 hours in cad planning (solidworks) and 80 hours building this thing. Total price to build it from scratch would be about 1000-1300 euros (at least here in Finland).
    The machine uses chinese linear rails and ballscrews from ebay seller linearmotionbearings2008. With my 1.8Nm stepper motors and geckodrive g540 it can achieve 10m/min rapid and 5m/min feedrates.
    For project log please visit: AllTheMods - Hardware Modding & Tuning Gallery
    All the solidworks source files ( + edrawings ) & drawings as pdf are available here: 3 axis CNC router MDF ( metric ) by Metalfusion - Thingiverse
    The project is now 95% finished. I just need to assemble the box for electronics, fix some problems with second X-axis motor, add limit switches and some cable management etc. small stuff.
    Attached Thumbnails Attached Thumbnails Second MDF machine build. Free METRIC plans!-cnc2solid4.jpg   Second MDF machine build. Free METRIC plans!-05112010_008_.jpg   Second MDF machine build. Free METRIC plans!-12112010_008_.jpg   Second MDF machine build. Free METRIC plans!-20102010.jpg
    Second MDF machine build. Free METRIC plans!-22102010.jpg   Second MDF machine build. Free METRIC plans!-23122010_004_.jpg   Second MDF machine build. Free METRIC plans!-27122010_003_.jpg   Second MDF machine build. Free METRIC plans!-30122010_001_.jpg
    Registered mmcp42's Avatar
    Dec 2010
    UK
    nice looking build
    tried to see more on your build log
    but the link is a bit broken
    Registered Drools's Avatar
    Feb 2009
    Yes, very nice!
    A good coat of coloring would really make this one stand out!
    Machine grey or maybe green.
    Aug 2009
    Finland
    Allthemods was down yesterday, now it seems to be working again.
    Personally I don't really understand why people paint their MDF machines to look like metal. I know mdf releases some stuff to the air if left unfinished but it really can't be as bad as all the dust flying around.
    Dec 2010
    UK
    excellent
    link working a lot better today
    and a very good log as well as machine!
    Feb 2009
    The paint was more to prevent the MDF from taking on moisture that giving off fumes. I think it is important to seal MDF be it with paint or some sort of sealant.
    I suppose if you live in an area that never rains or gets very minimal rainfall it might be ok.
    Dec 2004
    Barbados
    Excellent machine Metalfusion. I also have a love for MDF machines as I built a JGRO a while back and it served me well.
    Jason
    Jan 2011
    Update?
    I see you posted this when the machine was still in construction. How did it work out for you in terms of precision and durability? Thanks!
    Aug 2009
    Finland
    I haven't had much time to work on the machine and so the progress has been slow. X and Y home switches are now installed and the machine is running with both motors on the X axis. I also had some problems with vibration/resonance when doing rapid moves on the X. Re-aligning the x ballscrew pretty much eliminated that thought.
    The project on Allthemods.com has been updated.
    I don't know yet about the precision but those cuts that I have already made came out pretty good. I should square the machine and then run some measurements to find out. The router also needs better mounting as it isn't exaclty perpendicular to the table surface.
    Aug 2009
    Finland
    Version 2.1
    Parts made from aluminium: Z-plate: 10mm, router mounts: 12mm, Z-nut mount: 12mm and top plate stiffeners: 6mm.
    All parts were cut by the machine itself.
    [nomedia="http://www.youtube.com/watch?v=Z4-Z0269LxI"]YouTube - DIY CNC 2 Aluminium z plate milling timelapse and machine breakdown[/nomedia]
    Attached Thumbnails Attached Thumbnails Second MDF machine build. Free METRIC plans!-19032011_002_.jpg   Second MDF machine build. Free METRIC plans!-19032011.jpg   Second MDF machine build. Free METRIC plans!-19032011_032_.jpg   Second MDF machine build. Free METRIC plans!-05032011_001_.jpg
    Aug 2009
    Finland
    I finally got around to release the updated solidworks files and drawings that include the aluminium parts.
    Aluminium upgrade kit for CNC router by Metalfusion - Thingiverse
    Aug 2009
    Finland
    I did some measurements with a chinese dial indicator that has 0.01 mm accuracy.
    Measuring one axis at a time I jogged the machine to a position, reset the dial and mach3 coordinates and run it to different coordinate along the axis. Then back to zero and took measurement.
    X and Y axis seem to have position accuracy of about +/- 0.02 mm WITHOUT ANY LOAD.
    X had backlash of about 0.04 mm.
    The bad news is that these don't really matter as it is easy to inflict enough force by hand to make the dial turn +- 0.2mm.
    Also, I noted that after leveling the spoilboard with the machine itself it had about +- 0.1mm variation in heigh which is pretty good for me.
    However, along the X-axis, on the other side of the table the height was about + 0.5mm which could easily ruin details on V-carvings and halftone patterns that I have been making lately.
    Maybe the solution is to replace more parts with ones made from aluminium
    http://www.youtube.com/watch?v=REu3MBDsNWo]‪Diy cnc cut halftone pattern‬‏ - YouTube
    Attached Thumbnails Attached Thumbnails Second MDF machine build. Free METRIC plans!-stp81240.jpg   Second MDF machine build. Free METRIC plans!-stp81149.jpg
  • Page 1 of 2 12 LastLast
    1. Plasma Table Build Log Including Free Plans Link, & Pictures by Weldtutor
      By Weldtutor in forum Plasma, EDM and other similar machine Project Log
      Last Post: 10-15-2012, 08:32 PM
    2. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
      By Modular CNC in forum Open Source CNC Machine Designs
      Last Post: 11-08-2009, 12:36 PM
    3. Free CNC Drilling Machine Plans
      By yarko in forum Hobby Discussion
      Last Post: 10-04-2009, 11:11 AM
    4. looking for metric plans
      By stem fan1 in forum Steam Engines
      Last Post: 03-24-2008, 10:54 PM
    5. JRGO Plans in metric
      By Drakkn in forum JGRO Router Table Design
      Last Post: 01-23-2007, 12:10 PM
