Results 1 to 10 of 10
Thread: Stepper Motors
    Feb 2007
    Stepper Motors
    I have 3 of the following motors 17PM-K303-G3VS by Astrosyn. I have contacted the manufacture for info, and they told me they can't supply me with info as they were specially made for another company. These motors came out of a photocopier. If anyone can help me with getting the specs on these motors and what controller I should use with them I would really appreciate it.
    Haku
    Oct 2005
    Please post a photo of the motors, then it will be easier to guess ratings or a test procedure to find the ratings.
    Feb 2007
    Ok here is a picture of it. I would like a DIY controller as I can do the PCB etching and all of the soldering etc etc my self. I just don't want to design the thing.
    Haku
    Oct 2005
    It is a size NEMA 17, and has a standard 6 wire unipolar connector;
    orange A1
    white (common, A +power)
    blue A2
    red B1
    black (common, B + power)
    yellow B2
    Being small, size 17 in a single stack (short length) they won't have a lot of power. Generally they run about 2 watts per phase or so.
    If you can measure the ohms between orange and blue wires i can tell you the approximate volts and amps needed for the motor.
    The type of driver will depend on the volts/amps of the motor and if you want good microstepping performance, or if you want one that is very easy to build and has less performance.
    Feb 2007
    Ohms between Orange and Blue wires is 5.4 ohms
    Haku
    Oct 2005
    That's fairly low ohms. It means each unipolar phase is 2.7 ohms.
    At a phase power of about 2W that means the motor is 2.3 volts and 0.85 amps per phase, if you are driving full step with 2 phases always on.
    If using a microstepping driver you could probably go up to about 3W per phase or 2.8v and 1.05 amps per phase.
    Since the motor is around 1 amp per phase you can use most of the low cost stepper driver chips, assuming you still want to make your own PCB etc.
    You do know that with small motors like these they are only suitable for a very small CNC machine, like a little PCB engraver etc?
    Feb 2007
    How would these motors work KL23H256-21-8B Specs here Stepper Motors-kl23h256-21-8b.pdf
    What my goals are is to drill / route PCB's. and do some HDPE or Nylon routing, and perhaps some aluminum milling.
    Haku
    Oct 2005
    I'm not sure, I don't open unknown PDFs.
    If you want to work with more serious cutting, especially metals, it's worth reading some build threads and looking at other people's solutions including how they made their machine rigid enough and what motors/drivers/leadscrews etc they used.
    Like anything, if you start spending lots of $$ it gets easier to get high performance.
    Feb 2007
    For a controller that I can use now and in the future if I upgrade my motors I have been looking at the controller from here
    http://www.pminmo.com/kreutz/mkuni.htm
    or
    http://www.pminmo.com/SLA7062/SLA7062.htm
    The 2nd one is easier to build.
    Would that be sufficient?
    Haku
    Oct 2005
    If you want a SLA stepper driver I think the best one by far is this one;
    SLAm Stepper Motor Controller, Allegro SLA7062M, Unipolar
    but then I'm probably a bit biased seeing as I'm the guy that designed it.
    If you want to save a few dollars and do all the work of etching and drilling your own PCBs and sourcing all the different parts the PMinmo version will be a little cheaper. But if you want really nice (and small!) PCBs and very easy construction, the SLAmSteppers are the way to go. I have 3 on my CNC machine.
    1. Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China
      By Ling in forum Product and Manufacturer Announcements
      Last Post: 07-12-2009, 05:10 AM
    2. Wanted DIY stepper driver circuit for 6 wire stepper motors
      By Colin300 in forum Australia, New Zealand Club house
      Last Post: 09-20-2007, 10:20 PM
    3. stepper motors or servo motors?
      By jprobst in forum Torchmate
      Last Post: 07-13-2007, 06:37 PM
    4. Stepper Motors
      By tinwakr in forum Stepper Motors and Drives
      Last Post: 10-29-2004, 04:43 PM
    5. Stepper motors
      By robbycar in forum Australia, New Zealand Club house
      Last Post: 06-15-2004, 03:35 PM
