Results 1 to 2 of 2
Thread: Newb looking for advice on diy cnc mill thats rigid
    Apr 2010
    I'm looking to build a machine but am having a hard time deciding what to get and how to go about building this. I am a machinist (Blohm Profimat Creep feed grinder with sunimerik 810d) and have ALL capabilities to grind ID/OD, Blanchard grinding, centerless grinding and a whole lot of other capabilities. I also have access to a mill but no lathe at the moment. I am looking for a standard mill size, I don't know much about size but would say I want at least 32"X12" table. I am looking to machine all types of materials (steel, stainless, and some alloys included) so I need something rigid that could handle this. I have an unlimited amount of materials at my disposal and also am able to weld. So what I am looking for is blueprints or instructions or whatever can get this project going. I have searched extensively and everything seems to be geared toward machining soft materials. I am planning on a $2000 to $3000 budget and want to use mastercam x4 if possible. Please direct me to a good site or some prints. Also a material list would be great. I also am debating between an acme thread or a ball screw and servo vs stepping? Any advice? Thanks in advance.
    Registered jsheerin's Avatar
    Aug 2008
    Try looking at the metal working section of cnczone for some ideas. This is the woodworking forum. I don't think I've seen any plans there though. People tend to build around the parts they find. As I'm working on designing a mill right now and gathering some parts, I'd say you will be hard pressed to make a metal working machine that's that large for that much money. I mean I guess if all your materials are free you might have a chance, but if you have to buy linear bearings and rails, ball screws, motors and drives and a spindle that will probably blow your $3k budget right there unless you can really find some good deals on used parts. You might be better off buying a used Bridgeport clone and converting it to cnc.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
  1. newb needs advice on pic project
    By anilam in forum PIC Programing / Design
    Last Post: 11-10-2009, 02:39 AM
  2. Need advice, newb question here.
    By DerHammer in forum Fanuc
    Last Post: 11-13-2007, 01:23 AM
  3. need more advice on rigid tapping
    By jeremyinnys in forum General Metalwork Discussion
    Last Post: 12-07-2006, 06:11 AM
  4. Advice for a Complete Newb on DIY CNC
    By waglo in forum DIY CNC Router Table Machines
    Last Post: 04-05-2005, 08:59 AM
  5. Bought a mill now what - Help a newb.
    By Hack in forum General Metal Working Machines
    Last Post: 02-26-2005, 04:51 PM
