Results 1 to 2 of 2
Thread: Not your typ. router
    Jan 2005
    Here is a CNC router design with high cantilevered rails and feed tables
    for full sheets of plywood. The P/C router is tucked in under the y axis to reduce the moment. CNC router parts are used for bearing trucks.
    The y axis has got a 4" CRS rail I am planning to use (2) 2" flat bars so that I can adjust them for linearity. I feel drilling two holes between the rails will provide a spot to use a spanner to spread the rail for adjustment.
    Attached Thumbnails Attached Thumbnails Not your typ. router-design-model.pdf
    Registered ahren's Avatar
    Feb 2004
    I would recommend against using 2 2" bars instead of a single 4" bar -- the 4" bar will provide significantly more stiffness to your machine, and there is already adjustment built into the carriages, so adjusting the rail is fairly easy with a quick loosening of bolts and a tap with a hammer. Otherwise, this is an interesting design.
    Ahren
    www.cncrouterparts.com
  1. Need Help!- with a Precix Table Router with Perske router
    By SignShop Grunt in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-08-2010, 05:08 PM
  2. CNC ROUTER KIT instructables router project
    By spotlight3d in forum EBAY ADS
    Last Post: 12-30-2009, 05:11 PM
  3. Build Thread- Building a CNC Router; by someone who can't build a CNC Router
    By Womble in forum DIY CNC Router Table Machines
    Last Post: 09-27-2008, 08:51 AM
  4. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 04:33 PM
  5. Surfcam PP for Isel router / Precix router
    By IvanTochev in forum Post Processor Files
    Last Post: 05-12-2004, 01:27 PM
