Results 1 to 5 of 5
Thread: High Speed Servo Based CNC controller board
    May 2010
    Hong Kong
    I am new to cnczone . I am doing research to build a precise CNC miller with high speed servos . I am living in Hong Kong, so I have good access to lots of resources in China .
    I recently sourced some cheap high speed 200W-400W servos with drivers . These drivers interface using traditional stepper motor signals inputs with encoder as close loop control with 1000/rev (good enough for many cases). With an operational speed of 3000rpm . The driver accepts a signal pulse frequency of 40KHz for optimum operation.
    I searched a couple of days from the net, I cannot find any suitable controller board to match such speed. pluto-p and many hoppiest board are all PC parallel port based. If I am going to build a 4-axis or 5-axis (even 3 axis) machine . The speed of the parallel port is not good enough .
    Does anyone know any usable PCI or PCI-express based boards that support 5 channel of stepper motor with additional generic I/O pins available?
    I target to run the system using Linux .
    Please give me some suggestions. Thanks.
    David
    Sep 2006
    Russia
    mesa 5i20 should work for you, drivers for EMC2.
    Dec 2003
    Galil is an excellent product.
    Sep 2006
    Russia
    galil can't work with linux, right?
    Dec 2003
    According to the Galil site it does.
    Linux interface is offered.
  1. PC Based high-end CNC controller
    By CNCcontrol in forum Product and Manufacturer Announcements
    Last Post: 05-27-2009, 03:15 PM
  2. Replies: 2
    Last Post: 01-24-2008, 05:33 PM
  3. speed control with MIDI servo controller?
    By dondeaida in forum RC Robotics and Autonomous Robots
    Last Post: 07-26-2007, 09:05 PM
  4. Servo Controller BOard
    By venomx999 in forum Servo Motors and Drives
    Last Post: 12-27-2006, 01:37 PM
  5. Speed/Torque Boost on Allegro 5804 Based Controller (???)
    By FrankG in forum Stepper Motors and Drives
    Last Post: 11-28-2004, 09:03 AM
