Results 1 to 5 of 5
Thread: CNC Router machining area table
    Registered Rick7702's Avatar
    Aug 2007
    Hi - I am redoing my CNC router to try and get more accuracy. I am building it all new from the ground up with new linear rails and leadscrews. I have used plywood in the past for the machining area table and I am not satisfied with the stability and it holding its flatness. I have looked into .250 aluminum but is seems to be very expensive. My table will be 14" wide by 24" long. I need the ability to make some kind of hold down system on it. I am looking for suggestions for materials that are available and low cost. Also, have looked at Corian and would like feed back on the use of this material. Thaks..Rick
    Mar 2003
    Shelby Twp, MI....USA
    Unless you buy aluminum tooling plate, it's very likely that .25 aluminum will not be very flat at all. And if it is, it will need to be well supported.
    I work with corian a lot, and it's also not terribly flat. If you try to mill it flat, it'll curl up.
    I'd recommend building a torsion box base, about 3" thick. My table is a 32"x60" torsion box, supported only at the ends, and even with 200 lbs on it (me), it'll stay flat to within 1/64".
    Aug 2007
    Gerry -
    Thanks for the response. Please explain what a "torsion box" is and where I might go to find out how to make one.....Rick
    Mar 2003
    http://thewoodwhisperer.com/episode-...e-torsion-box/
    Here's the frame for my table before the top and bottom skins were applied.
    Another First Router
    Apr 2009
    This stuff is pretty strong... they use it for concrete forms!
    http://www.mccauseylumber.com/pposp.html
    1. Chicago, IL area cnc/machining clubs?
      By Farasien in forum Mentors & Apprentice Locator
      Last Post: 07-20-2012, 04:13 PM
    2. WTB a CNC X/Y router 2' x 4' work area...
      By Robot Dude in forum Want To Buy...Need help!
      Last Post: 08-08-2008, 12:56 PM
    3. Cut area selection(UG type) for machining components.
      By thirumalkumarn in forum EdgeCam
      Last Post: 07-22-2007, 03:34 PM
    4. 120x240cm(work area) Router Table - steel/aluminium
      By Goose80 in forum DIY CNC Router Table Machines
      Last Post: 12-13-2006, 04:43 PM
    5. My Router (24x60 cut area)
      By planescott in forum CNC Wood Router Project Log
      Last Post: 08-19-2006, 09:25 PM
