| Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here. |
| LinkBack | Thread Tools | Search this Thread | Display Modes |
#565
| Hi guys did post this in gecko forum , but know roman is behind 2 things I asked there. Quick question on a gecko 540 are there enough input/output pins for : superpid spindle control / hall effect limit/home switches With leds. & tool probe . Cheers Riche |
#566
| yes there is have x,y,z limit in terminal 1 x,y home in terminal 2 probe in terminal 3 you set z limit as home as well. superpid goes into Pos 7 VFD GROUND, Pos 8 VFD OUTPUT, Pos 9 VFD +10VDC thats how i have it set and it works good. Last edited by daniellyall; 01-29-2012 at 04:40 PM. |
#567
| hi john_100 i measured the voltage at a conection i put on the wire not at terminals, before i put in 2k resistors mach3 could not find switch as i used auto set function. when i put 2 k resistors on input wire mach3 found it and set it with out any problem on diagnostics screen when i move magnet in front of hall switch light comes on for home switch that it is set to. |
#570
| To Foam27- Hi, and sorry you can't use the SS40A. That is a "bipolar" hall switch, it needs a north pole (approx 50 gauss) to turn the switch ON, then to make it turn OFF it needs a south pole (approx -50 gauss). Although you might be able to rig some special magnet arrangement to get it to work I really recommend using the SS441 as suggested everywhere in this thread. |
#573
| You can combine the probe with a Home switch, but not a limit switch.
#575
| Yes
#576
| Therefore I was thinking to put the output of the first sensor to the ground of the second sensor. The output of the second sensor to the BOB with a pull-up resistor. For using the sensors I see 2 options: - putting in the sensors inside the housing by machining the right shape and holes - putting the sensors outside and guide the magnetic field through the wall by using a steel pin What would you recommend Regards, Leo |
| Currently Active Users Viewing This Thread: 5 (1 members and 4 guests) | |
| tamasi |
| Stepper Phase Current Made Easy | Rube | Stepper Motors and Drives | 1 | 08-30-2007 01:02 PM |
| The relationship of limit switches to home switches. | MikeAber | General Electronics Discussion | 4 | 11-04-2004 01:28 PM |
| Limit switches and home switches | viktorcnc | TurboCNC | 2 | 08-03-2004 06:11 AM |
| Home switches and limit switches. | ynneb | General Electronics Discussion | 5 | 04-08-2004 05:32 PM |
| Home made CNC mill (and some products made by it) | gcamlibel | DIY-CNC Router Table Machines | 23 | 04-05-2004 05:54 PM |
