TB6560HQ-Stepping Motor Driver IC 3.5amp - Page 15
Page 15 of 23 FirstFirst ... 512131415161718 ... LastLast
Results 169 to 180 of 271
Thread: TB6560HQ-Stepping Motor Driver IC 3.5amp
  1. #169
    Gold Member pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    Quote Originally Posted by winch1 View Post
    Hi
    Please find short vid attached re noise as requested.
    If the motor in the video is always stepping and just changes step rate, then your hearing the motor step. Has nothing to do with the toshiba. If when the clik is slow the toshiba is not getting step pulses, then there is an issue.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  2. #170
    Banned
    Dec 2009
    Hi
    Yeh, that is kinda noisey. Could it be from making on perf board?
  3. #171
    Dec 2009
    UK
    Quote Originally Posted by pminmo View Post
    There are no missed steps and without any step input pulses the motor is locked and silent, so I guess all is as it should be. I have found circuit layout and component spec is important with the 6560, but what a great chip for 24 volt systems if high speed is not necessary.
    Thanks for your prompt replies and interest.
  4. #172
    Dec 2006
    Germany
    ... but what a great chip for 24 volt systems if high speed is not necessary.
    If you use the TB6560A, so you can use up to 34 V DC.
    LazyBee
  5. #173
    Banned
    Dec 2009
    Someone posted in a different thread about the 6560 chip, he said it ran quietly-
    Quote Originally Posted by cartasu View Post
    I ve bought a four axis controller bord with tb6560HQ´s on it and it works quiet and great and after some badly running L297\L6203 selfmade solutions, this is it.
    So I did buy eight of theese smileys, to create my own PCB.
    Yet I started layouting, with the chip in a lying position to use both copper layers, with the chip in a hole in the pcb plain, looks nice. Now I am struggeling with the direct control via digital Joystick. Seven comparators and some and´s giving direction- ,and using a 555 the clock-signal (here I had to change some)
    found this on the web, have a look and tell me some
    http://www.cnczone.com/forums/showth...478#post720478
  6. #174
    Mar 2007
    Default Anyone know what the 74HC08 is used for in calladon1's circuit?
    Quote Originally Posted by celladon1 View Post
    Added the values of resistors R5...R10 to the sch. A brd changed a pay again.
    The input to the 74HC08 has a resistor,diode and a cap.
    Has anyone built and tested this board?
    B0SC0
  7. #175
    Mar 2007
    Quote Originally Posted by B0SC0 View Post
    Anyone know what the 74HC08 is used for in celladon1's circuit?
    B0SC0
    Anyone???
  8. #176
    Gold Member
    Jan 2005
    Toronto, Canada
    Anyone???
    What circuit? Do you have a link?
  9. #177
    Mar 2007
    Quote Originally Posted by H500 View Post
    POST 147
    http://www.cnczone.com/forums/showpo...&postcount=147
    B0SC0
  10. #178
    Gold Member
    Jan 2005
    Toronto, Canada
    Unfortunately, I don't have Eagle set up on my computer.
  11. #179
    Registered TigerPilot's Avatar
    Mar 2005
    Dominican Republic
    I have followed this thread a long time. I had posted here before and even done some layout in preparation for making a few boards. I stopped it because I can now get the driver, a three axis board (or four), on Ebay cheaper than the parts will cost me at Digi-Key.
    Yoram
    Just increased my count by one. :)
  12. #180
    Banned
    Dec 2009
    Default GND
    Does or should signal/5v supply ground be connected to the same ground as the motor supply ground?
    I'm sure it wouldn't hurt if they were connected, but I'm trying to design a super simple single sided board for the chip, and it's getting in my way.
