Open source low cost servomotor controller - Page 12
Page 12 of 12 FirstFirst ... 29101112
Results 133 to 138 of 138
Thread: Open source low cost servomotor controller
  1. #133
    Gold Member joeybagadonuts's Avatar
    Jun 2008
    SoCal USA
    Default Re: Open source low cost servomotor controller
    Macdowswe,
    You are doing a most awesome job regardless of the rumors the guy from the sunshine state is spreading.
    Got to get back to the bakery now.
    JoeyB
    A doughnut a day keeps the doctor away.
  2. #134
    Gold Member
    Jun 2010
    I've been manipulated into accepting the following concept, there is little difference from a machine for hobby use and a machine for commercial/production use, I should expect the same performance, repeatability, precision and power based on the platform size.
    Dunno about 'manipulated', but I will go along with the demand for quality.
    Perhaps one should back off slightly and treat the area as being not one monolithic beast but several overlapping markets.
    There is the cheap Chinese wood router market for hobbyists. If someone wants such a machine for a few k$, fair enough. It's a hobby. Treat as such.
    There is the cheap Chinese 'router claiming to be a mill' market, which is where a lot of the problems arise. I'll pass on that one.
    There is the not so cheap hobby mill, which can range up to - $10K maybe? Your call.
    Thene there is the serious hobby and light machine shop market. Easily up to $15k.
    The last two should be able to handle hard aluminium and, I would hope, steel. I would expect tolerances down to 0.01 mm for the more serious machines, with resolution well below that.
    The motor powers I quoted allow me to machine steel, SS and titanium accurately. Dunno about the speeds: I work in metric, but my machine and expectations are maybe lower than yours. That's OK: I am more concerned with quality than speed. My machine meets my requirements for quality. Cutters for steel and Ti are a bit more expensive if I want them to last.
    Cheers
    Roger
  3. #135
    May 2016
    I am excited to let you know that the time has finally come for the alpha stage of the ODrive project!
    Alpha release
    This consists of two components, the alpha software release and the manufacturing run for ODrive v3.2.
    The alpha release will include all the core features of the board, and allow go-to commands sent over USB, as well as step/direction interfacing. You can check which features will be included in the release on the roadmap.
    ODrive v3.2
    The new design is ready, and can be reviewed on github. The design will go to production on Monday the 17th of April, and you can get in on the production run here.
    More info
    If you want to read more about it, you can check out the blog post.
  4. #136
    Gold Member
    Dec 2007
    Wow that demo video is mad!
    When does the 3/4 axis come out? ;-)
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  5. #137
    May 2016
    Hey Ian, Thanks!
    The plan is to make v4 3-axis. But it will be at least half a year until v4 is ready. But you can just use two v3's connected over CAN to get a 4 axis setup.
    Cheers,
    Oskar
  6. #138
    May 2016
    Just wanted to let you guys know that there is an ODrive community getting started over at https://discourse.odriverobotics.com, with some discussion that you might find interesting.
    Cheers!
