DIY BLDC / DC Motor Servo Drive - ARM MCU (STM32F103C8T6) - Page 4
Page 4 of 24 FirstFirst 123456714 ... LastLast
Results 61 to 80 of 472
Thread: DIY BLDC / DC Motor Servo Drive - ARM MCU (STM32F103C8T6)
  1. #61
    May 2006
    Romania
    Default Re: DIY BLDC / DC Motor Servo Drive - ARM MCU (STM32F103C8T6)
    Quote Originally Posted by Holzwurm56 View Post
    the 6N137 has a inverted logic. I orderd the HCPL3180 from China for 1$. I do not know about the quality, when I receive them I will test.
    Hans
    6n137-I, seems to be half price (half frequency also) and positive output, but I do not think we need that super speed. We have only 20kHz in PWM speed... (wanna change that? )
    http://www.tme.eu/ro/Document/71c7b9...e816/6n137.pdf
    Mihai
  2. #62
    May 2006
    Romania
    Quote Originally Posted by tivoidethuong View Post
    HCPL3180 is mosfet gate drive opto, you can direct drive mosfet
    gud choice
    I must admit I do not get this very well... You mean we could use a couple of those to drive directly the low and high side of a half bridge without using any other dedicated circuitry? How do they work? We do not need a Higher voltage for high side?
    Hmmm... I do not get it... please elaborate with a schematic... could we drop the ir2101s?
    Mihai
  3. #63
    May 2006
    Romania
    I must thank here to the user tivoidethuong who offered to give me for free a DC motor for testing. Thanks again! I appreciate it. You can make a special request for the code ))
    I just bought from ebay a used servo. Dunkermotor GR42x25 mit Getriebe PLG 32, i=6,25:1, 12V-24V/DC, 3600 U/min | eBay
    I think it will do just fine for our DC motor testing. I will add DC motor support after I will receive it... I presume nothing will change in the schematic... so go ahead with your designs...
    Please do not forget to add a jumper from PB1 to 3.3V for the bootloader...
    Mihai
  4. #64
    May 2006
    Romania
    Hi Mihai,
    maybe I can build the pcb some smaller, but I will produce the prototype with isolation milling. I think the power-pcb is 100 x 60 mm, so both parts has europaformat. Can the Arm reads a thermoelement type K directly, is there a internal multiplicator for the analog inputs build in? Its possible to program an outputpin to enable the integrated powerbridge. I have orderd the optos in China and they are very inexpencive. Quality?
    Hans
    I do not think we can add the type K termo sensor directly to the ADC.
    From what I understand from this picture: https://en.wikipedia.org/wiki/Thermo..._functions.svg
    we have a variation of 10mV for 250 Celsius... our ADC is 12 bit with VRef set to 3.3, so this gives us o theoretical resolution of 3300 mV / 4096 = 0.71 mV... not very good for measuring a few milli Volts... So we need to amplify that signal...
    Mihai
  5. #65
    Mar 2005
    ASIAN
    about opto mosfet gate drive
    1. bostrap like ir2101
    2. independent 15V voltage source for high side
  6. #66
    Nov 2005
    Germany
    if its not possible to read the K-sensor directly with the Arm it will be not a problem to insert a special operationamplifier ic. I do not know the manual from the ARM but some microprocessors have integrated programmable gain for some of the analog inputs. For the power pcb I will use a integrated bridge IRAMX20up60a there the mosfetdriver built in.
    Hans
  7. #67
    Mar 2005
    ASIAN
    Hans
    if you are use iramx20up60a, i dont think HCPL3180 suitable
    6n137 is good choice
    opto for direct mosfet gate drive
    Isolated Gate Drive Optocouplers
    opto for IPM interface
    IPM Interfaces
    about positve ON or negative ON, you can modify stm32 code
    tivoi
  8. #68
    May 2006
    Romania
    Hans
    From what I know there is no way to set the gain in the STM32F103 ADC (old ATMega644 that I am familair with had such features). And since we need the Vref to be at least 3.3 V in order to measure the used current as good as possible we can not decrease Vref. So you need to boost the signal from the K Thermo in order to measure it good. But by the way... Do you intend to something with the value measured like limit the current and stuff? or you just want to stop the circuit on overtemperatures?
    Mihai
  9. #69
    Nov 2005
    Germany
    Hi Mihai,
    only stop at overtemperature. This feature must not work from the first time, but its easier when its possible in the pcb.
    Hans
  10. #70
    Dec 2012
    Norway
    Instead of trying to read the thermocouple directly or trying to make an amplifier to be able to read it, wouldn't be easier to just use a MAX31855K chip?
  11. #71
    May 2006
    Romania
    Quote Originally Posted by Stigoe View Post
    Let's keep things simple please...
    Mihai
  12. #72
    Mar 2005
    ASIAN
    i recommend use dido for temp protec
    Capgo - Semiconductor Temperature Sensors
    Attached Images Attached Images
  13. #73
    Registered James Newton's Avatar
    May 2005
    The TIL191 and TIL192's appear to be obsolete... Does anyone know a current part number? I'm trying to figure out the total BOM cost.
    James hosts the single best wiki page about motors for CNC hobbyists on the net:
    http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
  14. #74
    Member jalessi's Avatar
    Feb 2007
    Post Re: DIY BLDC / DC Motor Servo Drive - ARM MCU (STM32F103C8T6)
    James,
    I believe Newark still has the TIL191:
    TIL191 - Buy ISOCOM TIL191 Online at Newark element14
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  15. #75
    May 2005
    Quote Originally Posted by jalessi View Post
    James,
    Jeff...
    Is there no modern replacement? Should we be making new designs based on chips that are becoming difficult to source?
  16. #76
    Mar 2005
    ASIAN
    i thinks til191 can replace by pc817
    http://www.sharpsma.com/webfm_send/1092
  17. #77
    Nov 2005
    Germany
    here is my next pcb from the controlpcb. I hope the thermosensor type K can connect to the opamp. For current sensing the arduino isolated modul can be used. The power pcb comes soon, I will it use for variable frequency drive and the servo drive. The vfd is a project in the german microcontroller forum.
    Hans
  18. #78
    Nov 2005
    Germany
    here is my first design from the power pcb. Hi Mihai its possible to use a pin from the to switch the power bridge on or shut down?
    Hans
  19. #79
    May 2006
    Romania
    Hans
    Sure thing Hans. Any other free pin can be used as GPIO. What pin would be good for your design?
    Mihai
  20. #80
    Nov 2005
    Germany
    Hi Mihai,
    I think B0, B1, B10 or B11.
    Hans
