SMD part, i think need used 2 layer PCB, let me try
sori my poor english
Ah, thank you for noticing, I had two versions of R32 power resistor on the list. I've removed the duplicate and kept your suggestion. That brings it under $35 for parts in single quantities. (it's near $18 each in 100's). Plus the PCB. And then the motor and encoder (Ah! What encoder did you use? Is it still the one from the mouse?)
And your assembly labor, of course... even with the network resistors it's a lot of soldering! LOL.
And for that you /should/ get at least 2 AMPS but perhaps 25 AMPS at up to 48 volts. And for sure 1500 RPM, but perhaps 3000 RPM. Promising, but it would be really good to have some more testing. Remember, if you order that parts list, you will need to replace the two network resistors with individual resistors unless you lay out a new PCB.
James hosts the single best wiki page about motors for CNC hobbyists on the net:
http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
Hello again
For the encoder I chose a cheap avago encoder:
AVAGO TECHNOLOGIES - HEDR-5420-ES214 - ENCODER MODULE, 200CPR, 5MM, 2 CHANNEL | Protehno
This particular one was available in Romania, fits my motor shaft, and has 200CPR (in fact that is 400PPR, so the board record 400 pulses per revolution)
The motor I used is bought from ebay around 25 british pound per piece.
I can get more than 3000 RPM with it with my board. I am also sure that the final stage with irfz44 can handle 20A at ease... at 5A it does not heat at all... but this depends a lot on the mechanical load conditions.
Mihai
Cool. I found that encoder at Mouser and added it to the parts order list. $28.
Are these the sort of motors we could expect to run:
"ac servo motor" | eBay
Those are servo motors. They have already the encoder included. it's no need to buy another one.
if you just want to test you can use those cheap BLDC motors available for RC.
brushless motor | eBay
basically you can use any kind of AC motor as long as it has 3 wires
Playing around with board designs.
SMD and Through hole on same board.
Top:
Bottom:
Thoughts?
Hi hi hi....
We are getting pro tuning...
I've made some changes in the Firmware and with the help of an additional tool written in Delphi (Servo Drive Tuner) we can observe the response from the motor...
What do you think? Maybe we can invent something like an automatic tune button!
Mihai
You also have the firmware, schematic and source code and binary for this new tuning tool!
jdholbrook, It's great you are doing board layouts! May I suggest you re-do the through hole board so that it makes use of network resistors instead of requiring so many individual resistors? Cutting down on the parts count makes a difference. I love the mixed hole and SMD board!
New firmware and tuning program!
A new feature has been added to the tuning software to be able to measure PID frequency (how many times per second the PID output is updated).
After optimization of the firmware I was able to reach 8.3 kHz for PID frequency! pretty good!
A good guide for tuning your servo (if you reached that point) is located here: A Simple Method for Servo Motor Tuning - National Instruments
The movement is very smooth both on high and low speeds if PID is tuned correctly! What you see there gets at max 12000 mm per minute. 15000 can be reached with a longer axe without increasing acceleration too much. So basically no problem to reach 3000RPM with the motor!
Mihai
So this is looking really good. I took a glance at the code again today and an idea struck me. I think I'd be interested in taking this and replacing the brushless motor control stuff with regular DC motor code, and doing the same again and making a version with stepper motor output. Basically 3 versions of the same program.
My mill currently is being built with brushed DC motors. someday I know I'd like to upgrade to brushless. The way I'm building my servo control boards would also lend themselves to this idea, since I have a separate logic board and a driver board connected by just a 3 wires (enable, direction and PWM) A brushless version of my board would have 4 (enable, U,V and W).
I think I may have a go at trying mikropascal again. I'm curious to see how much its changed since version 2(the last time I looked at it).
Whipped up an SMD variant of the board.
Power res and IRF are through hole.
50x100mm
Forgot the resistor array.
very very nice...
If I could only produce PCB's like this...
DONATION!
Hello everyone!
I am donating a Servo Board as seen in the picture, without the ATMega644 and the IR2101s. It contains all other parts, including radiator.
It's an older design, it has the power resistor soldered below the board, has a different pinout for the encoder and step dir enable signals.
The board is functional, was tested and helped during development.
I am asking only for the shipment money.
I just want whomever takes it to use it, test it and so on...
I'm waiting for requests
Mihai
mihai, i just sent you a private message - did u deactivated PMs?
im interested in your board for testing and hopefully serious cnc action, just have to get IR2101s which shouldn't be a problem at all.
Hello Chris
Sure thing! I can send the board to you. I will make a package asap. Just send me your delivery address!
I will ship it with regular mail, to be the cheapest possible!
Best regards
Mihai
PS: I can not send PM to you. The board says you do not have it activated.
