DIY AC Servo Drive - ATMega based - Page 2
Page 2 of 13 FirstFirst 1234512 ... LastLast
Results 21 to 40 of 256
Thread: DIY AC Servo Drive - ATMega based
  1. #21
    May 2006
    Romania
    Default Re: DIY AC Servo Drive - ATMega based
    Here is the latest source code and board as promised.
    Changes in software:
    New parameter added:
    END POSITION ERROR = when in a stable position if you move the motor shaft with external force (by hand or vibrations or stuff), it will remain unpowered until the error will be over this threshold.
    Changes in hardware:
    Added a capacitor to the high power line (50-100u / 50V)
    Changed Step/Dir/Enable coupling resistances from 1K to 100ohm (Enable signal is still ignored by software, will be fixed in next versions)
    Someone please start to build this and play with it! I need second opinions!
    Mihai
    Attached Files Attached Files
  2. #22
    Registered James Newton's Avatar
    May 2005
    Quote Originally Posted by mcm_xyz View Post
    Mihai
    First, HOW EXCELLENT! I'm very pleased to see you doing this and posting it open source.
    I would be interested in making a PCB or 20 if you could post gerbers and a PDF or PNG or something of the schematic instead of the Eagle board files. I'm trying to avoid installing, but more importantly, learning Eagle.
    James hosts the single best wiki page about motors for CNC hobbyists on the net:
    http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
  3. #23
    Jan 2006
    Part 1;
    A few years ago I built a BLDC driver with an AVR. My motor had hall sensors so I used a square wave 6 position truth table to determine the commutation. I used this system as opposed to the back emf technique so I would be able to run all the way down to 0 rpm. This was for a positioning application where the motor only rotated 33 revolutions and had just a single index pulse near the center of travel. I used the hall sensors for instant resolution of the commutation at any speed, but especially at full stop.
    I do not see a hall or back emf commutation solution in your code (I just quickly browsed it in notepad++) but I do see a sine-wave look-up table. Are you using the optical encoder with the look-up table? And if so do you have an index pulse or something? How do you determine position from a cold start? or if there is an error?
    part 2;
    I see you are using MikroPascal for AVR. I briefly looked at their offerings for AVR's several years ago, and at that time their AVR solutions seemed very buggy (while their PIC stuff was much more solid). Has this software matured since then? I seem to recall that the libraries were closed source and you were more or less locked into their hardware configurations if you used the supplied libraries. I did however like ME's IDE concept a lot. How do you like this software?
    Marvin
  4. #24
    May 2006
    Romania
    Quote Originally Posted by punisher454 View Post
    Part 1;
    part 2;
    Marvin
    Hello Marvin
    Thanks for your interest! Let me clarify...
    part 1;
    Back EMF indeed could not be used for cold start and it's very hard to use even for low RPMs. Hall sensors are indeed a good solution but my implementation does not use them, mainly for maintaining the code and schematics simple. Cold start is done the hard way . A short commutation sequence is applied to the motor with low speeds, then a pause is done, waiting for the motor to get stable. So, indeed a disadvantage, when starting, the motor will spin freely for a small part of a rotation. After that the commutation sequence is synced using the encoder position, a part of the algorithm maintains the correct commutation sequence (the sine wave table you saw) with the encoder position. So it's very important to know:
    1. exactly how many PPR your encoder has (Parameter ENCODER PPR)
    2. how many poles your motor has (Parameter MOTOR POLES). I am unsure of the terminology here... What I am expecting for you to enter here is how many times the full sine commutation table must be applied for the motor to make a whole rotation... I had motors with 4 and motors with 6. I expect there is a large variety on the market.
    without setting this 2 values correctly your motor wont spin. Or if your encoder looses steps the motor will not stay in sync and will stop after a while. But what good is a positioning system that looses steps
    part 2;
    Indeed, mikroPascal might be a disadvantage, mainly because it's not free. In my opinion this compiler has reached maturity a couple of years ago, starting with the PRO versions. I developed a complex project a few years ago in mikroPascal, an ATMEGA644 webserver that had ethernet, RTC, communication with other MCU's using UART over radio modules, temperature reading with 1-wire sensors and some relays. It was a smart management thermostat with schedules and wireless sensors. the whole thing works stable for weeks without a crash.
    In future I might migrate to C code in AVR Studio. I started with this because I am very familiar with it, my first development board was mikroElectronica...
    Hope this helps
    Mihai
  5. #25
    May 2006
    Romania
    Quote Originally Posted by James Newton View Post
    Sorry Gerber output form Eagle seems to be buggy. However I exported some large images of the schematic and some HPGL files. It's most probably that you could import those PLT files in your CNC Software directly and make a PCB. There are 2 files, one for milling and one for drilling.
    You can see how this file looks in my CNC software.
    Attached Images Attached Images
  6. #26
    Mar 2005
    ASIAN
    to: mcm_xyz
    why you dont try with stm32f103,
    it is cheap and have encoder interface , 72mhz, 32bit with give bester performance
  7. #27
    May 2006
    Romania
    Quote Originally Posted by tivoidethuong View Post
    to: mcm_xyz
    why you dont try with stm32f103, you can use with mikrobasic for ARM,
    it is have encoder interface , 72mhz, 32bit with give bester performance
    I am old school... I need something that I can solder myself... Just kidding...
    This has started as a hobby project. If in time something faster is needed I will probably switch to a different MCU.
    However the goal for now it is for this project to be fully DIY!
    Mihai
  8. #28
    Mar 2005
    ASIAN
    Mihai
    thanks you, exellent diy
  9. #29
    May 2006
    Romania
    Pretty good news...
    I've just made a quick dirty test... I've setup the MCU tu run with internal oscillator (8Mhz)... I am still able to achieve 1500 RPM so the speed limit I have now is given only by the power source... (Still waiting for the lab source)...
    So basically with 20Mhz and same encoder (400 PPR) there will be no problem to reach 3-4000 RPM. This I think it's more than enough for many uses.
    I've also changed the PID code allowing the integral part to accumulate more errors (10 errors in a shift register) and the movement is now even smoother...
    The only drawback I feel now is that we do not have a current sensing circuitry. Maybe someone could help me with that and give me some ideas...
    I will keep you informed and up to date with source code.
    Mihai
    PS. I managed to reach 2000 RPM with the actual power source by decreasing PWM Frequency by 8. But I hate the high frequency noise from the coils...
  10. #30
    Mar 2005
    ASIAN
    Current sensing, i think you can user comparator like lm393,
    detec peak current and check it every procedure UpdatePID
  11. #31
    May 2006
    Romania
    First tests on my new Z axis (unfinished yet)... Please do not lough about my motor coupling
    Things seem to be good enough
    Mihai
  12. #32
    Member Iron-Man's Avatar
    Jan 2009
    Mihai
    What you need is a precision current sense amplifier. Here are a few links to get you started;
    http://datasheets.maximintegrated.co...s/MAX44285.pdf
    http://cds.linear.com/docs/en/datasheet/6102fe.pdf
    http://www.ti.com/lit/sl/slyb165g/slyb165g.pdf
    See page 13 for TI current sense amplifiers.
    Hope this helps,
    Iron-Man
  13. #33
    Mar 2005
    ASIAN
    more option for current sense
    avago hcpl 7840
    Avago HCPL-7840 isolation amplifier for automotive
  14. #34
    May 2006
    Romania
    Hello dear machinists!
    I am finally satisfied! The movement is now so smooth you can barely hear anything.
    I am now sure we can reach 5000 RPM with 400 PPR encoder. (even if the motor says 3000RPM max )
    I found a bug in mikroelectronica's UART library. Sometimes, especially after power failures, the MCU entered a state where no data could be sent to it via UART. So I wrote my own UART implementation and all works perfect now.
    The sinus commutation table has been replaced by a square one and the PID process now controls PWM duty.
    Besides the fact that the circuit misses a current detector all is perfect! For this time I will use it like this. I will buy a separate PSU for each controller, with a power matching the motor, limiting the current like this.
    Also I received the LAB power source. The current consumption when no load is present is near 0!!!! Perfect again!
    Here is the latest firmware (reaching V 1.3).
    Enjoy the video!
    Mihai
  15. #35
    Mar 2005
    ASIAN
    Mihai, thanks for your share
  16. #36
    Jan 2006
    I believe you made the right call to ditch the sine table. Really just a truth table is probably the best. for whatever position the shaft currently is in you should always have the capability to apply full torque. My controller used 3 hall sensors and it was very easy to just look at the on/off status of all three input lines and pick one of six valid combinations. Very little overhead for this approach.
    I cant wait to get a chance to try this out.
    thanks
    Marvin
  17. #37
    May 2006
    Romania
    thanks
    Marvin
    Thanks Marvin for your comments and suggestions. I am still making the code better and better. It takes about 15K from the controller so far with 4K reserved for bootloader so mainly 11K for app. If can be fitted to ATMega 164 if needed but the price even for 1284 is quite the same... I will try to make a bootloader with firmware update capabilities. This way we can ditch the ISP port from the board. Also I might try to add a current detector circuitry, making this way this project able to compete with commercial ones...
    Mihai
  18. #38
    May 2006
    Romania
    thanks
    Marvin
    Thanks Marvin for your suggestions. I am improving and simplifying the code more and more. It takes 15K so far, with bootloader reserved 4K. So about 11k for app. I will try to make a bootloader with firmware capabilities also so we can ditch the ISP port.
    Also I am working at integrating a current sense circuitry, allowing this way for this project to compete with commercial ones.
    Mihai
  19. #39
    May 2006
    Romania
    Hi hi hi....
    A current limiting circuit has been added... Only used a 0.1 ohms shunt resistance and the ADC in the ATMega ... no other circuits...
    This give us a max limit to 50A until the ADC input clips. The 10 bit resolution of the ADC is also good enough to test low power.
    We might need to protect the ADC imput of ATMega with a zenner diode... The schematic is not updated yet but soon...
    Enjoy the video
    Mihai
  20. #40
    Mar 2005
    ASIAN
    Hi hi hi....
    Enjoy the video
    Mihai
    really cool, waiting your new shecmatic
