Page 103 of 181 FirstFirst ... 3 53 93100101102103104105106 113 153 ... LastLast
Results 1,225 to 1,236 of 2163
Thread: DIY Servo controller
  1. #1225
    Aug 2006
    Quote Originally Posted by tenmetalman View Post
    Kreutz
    Is this the connector you need ? 97-3102A-18-19S AMPHENOL Circular
    Connector. 97-3102A-18-19S AMPHENOL Circular Connector
    97-3102A-18-19S Circular Connector 93F1226 Image is for illustrative
    purposes only.
    Please refer to product description AMPHENOL
    Manufacturer: AMPHENOL
    Newark Part Number: 93F1226
    Manufacturer Part No: 97-3102A-18-19S
    RoHS Compliance :
    Description
    * Circular Connector
    * MIL SPEC:MIL-C-5015 A/B/C
    * Body Material:Aluminum Alloy
    * Series:97-3102A
    * Number of Contacts:10
    * Connector Shell Size:18
    * Connecting Termination:Solder
    * Circular Shell Style:Box Mount Receptacle
    I'll get a couple on the way ASAP.
    Paul
    Paul;
    I will check the dimensions tonight, as soon as I get Home.
    Thanks,
    Kreutz.
  2. #1226
    Registered Xerxes's Avatar
    Sep 2004
    Finland
    Quote Originally Posted by kreutz View Post
    The PWM frequency for the UHU board is 23.5 KHz, some old servo drives used from 5 to 15 KHz, the older technology, or higher power, the lower the switching frequency they use. So I expect a little more magnetic losses than usual on those motors.
    The filters I use are designed to control DV/dt on the motor. Depending on the turn-on time of the power Mosfets used in the H bridge, and the size of the motor; cable lengths as short as eight feet can result in motor peak voltages that exceed the rating of the motor's insulation system. However, the longer the cable the greater the problem. Dampening the rate of voltage increase will minimize the peak voltage that occurs at the motor terminals.
    When using low power/voltage motors the dv/dt could be effectively controlled using lower switching times, like in the original UHU design. When handling high voltages and currents, it is better controlled with external Snubbers, since slowing down the switching times could destroy the switching semiconductors.
    Could you explain why lower frequency would heat motors more? I think it has no significant impact on that since di/dt stays nearly constant anyway. di/dt can be calculated from supply voltage and total series inductance.
    Also the dv/dt during deadtime don't change as function of switching freq.
  3. #1227
    Aug 2006
    Quote Originally Posted by Xerxes View Post
    I don't mean that lower frequency heat more the motors, what I meant is that servo motors made for lower switching frequencies (made during the 80's and early 90's) have more magnetic circuit losses at higher PWM frequency, when used with the UHU board.
    dV/dt and dead-time are two separated concepts, if you design for lower switching losses on the output stage, dv/dt will increase. The only way to control dv/dt at the motor terminals is by using Snubbers (or output filters). Of course, when you make shorter mosfet switching times, dead-time will increase if you don't change anything else to adjust it. The rate of current decay during the dead-time depends on the Power supply voltage and motor inductance (fast decay) in this case (UHU board), due to the PWM signal being applied to the higher mosfet and opposite's H leg lower mosfets at the same time.
    Also, low inductance motors will have higher losses, and in some cases will be unstable when employing blanking time on the current sense circuit.
  4. #1228
    Dec 2005
    CANADA
    I've just received the Embeddedtronics PC board for the UHU controller and I'm waiting for the processor to arrive. Meanwhile, I'm collecting the bits and pieces needed to build it.
    On the motor side I have a question about the encoder for the servo motor. I'm planning on connecting the UHU to a lathe Z axis driven by my Electronic Lead Screw. It's limited to a 20kHz stepping rate.
    So here's the issue. With a 200 line encoder, the UHU controller appears to use that in quadrature so that's 800 ppr. The implication if I understand the configuration then is that 20000/800 = 25 rev/sec or only 1500 RPM. That's pretty slow for a servo but more than adequate for a stepper drive.
    If the servo has a top speed of say 6000 RPM then I expect I'll want to either have a 50 line encoder or have the motor move 4 steps for every one step input. But I'm having trouble interpreting the parameter Step Multiplier (M) which appears to suggest that each step is really one encoder line or 4 quadrature steps.
    A 200 line encoder in quadrature mode I think is the same as the document's 4-fold interpreted encoder line. So does a one step input create a 4 quadrature step (one encoder line) and if M is 2 then one step does 3 encoder lines or 12 quadrature lines?
    If that's the case then I can still stay with my max 20Khz stepping rate but have the servo move 4 times as far with M=3 and use a 4:1 pulley to bring the lead screw RPM down to 1500 RPM max.
    John Dammeyer
  5. #1229
    Aug 2006
    Quote Originally Posted by jcdammeyer View Post
    John Dammeyer
    The quadrature code produced by incremental encoders has 4 state changes (edges) per quadrature cycle (one per cycle). A 500 CPR encoder has 500 cycles, (2000 codes) per revolution. X1 decoding means that the external electronics counts only once per full cycle. X2 counts two states per cycle. X4 counts every quadrature state.
    UHU's decoder is X4, and as you stated, will produce 800 counts per revolution with a 200 CPR encoder.
    On the UHU's user's Manual it says:
    "Step multiplier (M)
    The provided integer value is added supplementary with every step pulse. I.e. if 'M' is set to '2', the
    motor moves exactly three 4-fold interpreted encoder lines with every step pulse.
    This makes it possible to drive setups with high encoder resolutions to high speeds even if the
    commanding PC is limited in Terms of stepping rate. As it also reduces overhead operations, it is
    always desirable to increase this parameter if the resolution of the encoders is not needed.
    Attention: Setting 'M' to a high value leads to higher tracking errors with every step. The tracking error
    shutoff 'E' has to be increased accordingly.
    Useful values are 0 to 20."
    Yes. and as an added bonus, you will be using all the motor's available torque at the maximum lead speed (1500 rpm).
  6. #1230
    Oct 2006
    united states
    could i buy completed units from you? as a neewbee are these unit like a gecko 201
    oporter@earthlink.net
  7. #1231
    Dec 2005
    CANADA
    Quote Originally Posted by BIGO View Post
    At the moment I'm not considering assembling these boards. They're not really labour friendly in that it takes a while to assemble them.
    Not having a Gecko to play with I don't know how much better it would be over a Gecko and they're on sale right now.
    I did post a question asking whether tuning via software (UHU) or via trim pots (Gecko) is better. No one has answered that question.
    I wouldn't buy another UHU-Servo Embeddedtronics board. Although it's a compact layout, the TO-220 mounting holes are way to small with undersized pads for the kind of current that this system could deliver. Blow a transistor and it's quite likely the board could be damaged replacing it.
    I bought the larger IRFP260N devices and they won't even fit in the holes much less have the right spacing for the holes. I had IRF640s in stock so that's what I ended up using. That's fine for this motor and experiment because 18A is max stall current for the motor anyway so I just have to limit it to 15A or so to protect the transistors.
    Each time I build up a through hole board I remember how much I dislike through hole boards. Surface mount is so much easier.
    I've attached a photo of the completed board and motor. Now I need to build up a good solid 24V power supply and get the proper pulleys so I can hook it to my lathe and try it out with the Electronic Lead Screw.
    John Dammeyer
    Attached Images Attached Images
  8. #1232
    Apr 2004
    Michigan
    John Dammeyer
    Hi John,
    We only designed the board layout for TO-220 sized FET's. The size of the pads and traces should be more than adequate for 20amps. IRFP260N are much bigger devices.
    I put a new disclaimer on our website that reads...
    "*UHU board has only been tested with IRF540N FET's at 60volt/20amps. Using any other type of fet driver and/or higher voltage or current is the sole responsibility of the end user. Using high voltage and currents is dangerous. Building and using the UHU servo board is at your own risk. Embeddedtronics cannot be held liable or responsible or will accept any type of liability in any event, in case of injury or even death by building and/or using or misuse of this device or any other high-voltage device posted on this web site. By accessing, reading, and/or printing the articles presented here you agree to be solely responsible as stated in the above disclaimer and exempt Embeddedtronics from any criminal and/or liability suit. Safety is a primary concern when working with high voltage circuits."
    We care for your safety so officially we will just limit our version of the UHU board to 60volt 20amps. However we cannot control what type of fet, voltage and current that people use once they buy our board. Please be safe when using high voltages!
    I'm pretty sure IRF540N is the same fet that gecko uses. They conservatively rate their drive at 80volts 20amps. I don't have a power supply bigger than 60volts so that is the rating I will use for our version of the UHU board.
    regards,
    Jim
    Embeddedtronics.com
  9. #1233
    Dec 2005
    CANADA
    Quote Originally Posted by jfong View Post
    Hi John,
    regards,
    Jim
    Embeddedtronics.com
    hi Jim,
    If you do a Rev. D layout here are a few of suggestions.
    1. Make the board a bit larger so that the mounting holes don't need insulating washers to avoid shorting the traces nearby. Make the holes work for 4-40 screws and nuts with room around the nut. Also allows the board to be held in an assembly frame so the foam panel can hold the parts down while soldering. See point 4.
    2. Separate the 12VDC power in connector a bit more from the Data and Encoder input connector. I had to bend the pins on the connector to make it fit.
    3. Spread the TO-220 package pins further apart so that wider anular rings can be used with larger holes. Both of those will contribute to serviceability when a FET is toasted and the magic smoke comes out. In fact, design it for the IRF260 foot print. Large holes, large pads.
    4. I prefer to lay resistors down rather than the vertical method used here. But I think that's a personal preference and your method certainly makes the board smaller.
    5. Set up the board to also have the ability to use an encoder with differential pair drivers for noise imunity.
    Other than that. Nicely done!!!! Appears to work quite well.
    John Dammeyer
  10. #1234
    Apr 2004
    Michigan
    Hi John,
    I'm glad the servo board works for you. Thanks, for the comments. We will look into making the changes in our next rev of the board. We haven't sold that many so it may be awhile before we need to order more boards.
    We welcome any comments on our version of the UHU servo board, both negative and positive. It will only help us design a better one the next time. It's hard to get things right the first time or even the 3rd rev. The first 2 had silly errors in the layout that we totally missed.
    regards,
    Jim
  11. #1235
    Dec 2005
    CANADA
    Hi John,
    regards,
    Jim
    Hi Jim,
    Been there done that. I'm fixing all the bugs on the second rev of the ELS board this weekend. http://groups.yahoo.com/group/E-LeadScrew/
    There's been a few silly mistakes. And now changes to accomodate a larger range of buttons, digital pot for setting stepper motor current. It's really easy to get carried away with 'features'.
    BTW, I was very happy to see that the pinout of the 3 pin RS232 connector on your UHU-Servo board matched the RS232 pinout on the pins of my ELS design. Saves keeping yet another DB-9 to 3 pin adaptor.
    John Dammeyer
  12. #1236
    Apr 2004
    Michigan
    hi Jim,
    John Dammeyer
    Hi John,
    We really can't take any credit on this. All the hard work is done by Uli and his servo chip. Many thanks to him for providing a servo chip/design for everyone here at cnczone.
    Jim
