autonomous cnc router
Results 1 to 5 of 5
Thread: autonomous cnc router
    Nov 2009
    Default autonomous cnc router
    Are there any plans or does the following even exist?
    I would like an autonomous cnc router that I can place on a surface and it is self-aware of its location and is self-contained.
    No table, no gantry, no rails. Just a self moving router that can adjust it's z-axis and move x and y on it's own.
    I guess it would need some sort of laser tracking to discover where it is and then follow it's instructions moving as necessary around the work piece.
    I can see this becoming an issue if it mills an area that is in its path of movement. Are there any products like this; what are they called?
    Zach
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: autonomous cnc router
    This is probably the closest you'll find.
    Handibot®
    UCCNC 2017 Screenset
    Nov 2009
    Wow, thank you. That was amazing. Years ago I bought an epilog zing 24 and did lots of cool craft stuff. But I always wanted to do shoji style panels. This tool is amazing. Thank you so much for pointing me in this direction.
    Registered jfong's Avatar
    Apr 2004
    https://printrbot.com/shop/printrbot-crawlbot/
    Uses belts that you place on the surface instead of rails.
    Apr 2007
    https://shapertools.com/
    this one looks pretty cool..it uses a vision system to orient itself to the program and workpiece
