DIY Cable Carrier - Page 7
Page 7 of 14 FirstFirst ... 45678910 ... LastLast
Results 121 to 140 of 277
Thread: DIY Cable Carrier
  1. #121
    Aug 2006
    Shannon,
    Great job. Stumbled across this thread the other day as i have been looking for something like this for my own chains along with a mini cyclone(Damn MDF dust clogs the filters) for my next couple of projects for my mahcine.
    This is another one of these great posts that everyone will refere to and it will help every hobbyist make a professional looking machine cheaply and easily. Again its another step towards a completely homemade machine. Great work.
    Looking forward to cutting my own chains for my machine soon. You've just saved me alot of money.
    Thanks again.
    Daniel
    P.S Now if only someone can't make their own cheap CO2 laser. lol
  2. #122
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    I'm trying to see what keeps them locked together?
    Joe
  3. #123
    Jan 2006
    New Zealand
    Hi Joe,
    The outsides face each other so one link is comprised of two 'pin' side pieces facing inwards, the next link is comprised of two 'hole' side pieces facing outwards. When the top and bottom plates are attached they then hold the whole lot together.
    I can put up some pics to make it clearer if you like?
    Shannon.
  4. #124
    Jan 2006
    New Zealand
    Here's some pics to make it clearer.
    Enjoy....
    Attached Thumbnails Attached Thumbnails DIY Cable Carrier-dsc02738-jpg   DIY Cable Carrier-dsc02739-jpg   DIY Cable Carrier-dsc02740-jpg
  5. #125
    Aug 2004
    i see how you have it, i was just curious what keeps the sides from sliding outwards other than a tight fit of the top and bottom pieces, but i tight fit should work fine.
    Joe
  6. #126
    Jan 2006
    New Zealand
    Friction fit.
    I am thinking with the acrylic they can be glued (carefully) with some sort of solvent, the chain in my previous photos is a really tight fit and shouldn't come apart under normal use. Saying that, I may still end up gluing it all together.
    Shannon.
  7. #127
    Sep 2006
    Thanks for sharing. Just found the thread after seeing the pics in the gallery a few days ago. Great job. I've been thinking about this for a while. Kudos on your work.
    My Solsylva machine (my first cnc)
    http://www.cnczone.com/forums/showthread.php?t=44336
  8. #128
    Jan 2006
    New Zealand
    No problemo I now need to finish a machine so I can use some of it
    Everyone don't forget to put some pics up when/if you have made some.
    Shannon.
  9. #129
    Member Khalid's Avatar
    Apr 2006
    Pakistan
    good job
    if some body still copying then pls post some more pics
  10. #130
    Feb 2007
    I have been using some bonded hydraulic hose for a cable carrier. It is basically four 3/16" dia. hoses bonded together side by side. The hose is very flexible so it has a good bend radius, but it doesn't "walk" around as it rolls. I can pass my motor wires through one wire, limit switch wires through another, and 110V through yet another. I have about 10 months of use without any failure. You can find this in various diameters and numbers of "circuits". I crimped regular hydraulic fittings on the ends of the hoses and then used bulkhead fittings to attach them to my machine.
    drafterman
  11. #131
    Nov 2005
    See my carrier from this design in my thread :http://www.cnczone.com/forums/showthread.php?t=61076
  12. #132
    Nov 2006
    Big S, thanks for sharing your ideas. This looks like the way to go.
    Does anyone have the file in Vcarve format? I loaded the posted dxf file into Vcarve but the parts were huge and I don't know how or what dimensions to make them. After I loaded the file into Vcarve, the individual parts might fit on a 4x8 sheet of plywood.
    thanks,
    Doug
  13. #133
    Jan 2006
    New Zealand
    Hi Doug,
    The files are in metric, so if you set that when you load the file it may help. I could convert it to vcarve if that doesn't help any though. Great software that Vcarve pro.
    Shannon.
  14. #134
    Nov 2005
    Doug , the parts in the dxf are in mm (millimeter) you have to scale them if your using inches !!!!
  15. #135
    Jan 2006
    New Zealand
    OR you could make HUGE cable chain
    Shannon.
  16. #136
    Member gadman58's Avatar
    Dec 2007
    Default Inch DXF for E-Chain
    I would like to thank Shannon for posting the original dxf.
    I model this up because I want to make it different sizes, for different locations.
    This particular one is Shannon's dxf scaled for inch with one or two changes for the way I am going to cut it. I put on some dimensions just because I was apparently bored.
    I have not cut these yet, I am looking for some plastic that I can afford.
    Glenn
    Attached Files Attached Files
  17. #137
    Nov 2006
    Smile
    Would somebody give me the dimensions of the CNC that I would need to go with my cable chain Just kidding..
    I think you guys have given me enough information to get these cut. I should be able to let you know tomorrow night. Don't know if I have a bit small enough to make the radii (I guess that is the plural of radius).
    thanks guys,
    Doug
  18. #138
    May 2006
    Quote Originally Posted by DougO View Post
    At a rough guess... about 25.4 times larger than you were thinking of
    Russell.
  19. #139
    Aug 2006
    Katy, Tx
    A big THANK YOU to Shannon for posting the original files.
    It had to happen.... I have been very lax with my cable management. In my own carefree way, I had been "making do" with hanging the wiring and power cable to the X axis from a hook, dangling from the open garage door. Well, last week I accidentally closed the garage door while everything was still attached, Unfortunately the garage door is a LOT closer to the X axis when open than it is when closed
    I had been shopping online, along with everyone else I guess, for some cable carrier when I decided to make my own. I followed the lead of Shannon. A few dimension changes and a couple sheets of PVC later and my cables were neatly packed away.
    Attached Thumbnails Attached Thumbnails DIY Cable Carrier-sm_img_1307-jpg   DIY Cable Carrier-sm_img_1308-jpg   DIY Cable Carrier-sm_img_1311-jpg
  20. #140
    Jan 2006
    New Zealand
    That looks great, the CNC almost looks like a commercial one, I think the purple and grey go together well too. Glad to see someone making the most of the files.
    Did you manage to get the parts to fit together tightly or did you just glue them together (or both)?
    Shannon.
DIY Cable Carrier
DIY Cable Carrier
