Sign Making Machine
Early time, craftmen used hand to produce wooden signs. A single mistake could wipeout weeks of work. In mordern society, peopel requires more speedy working progress, sign making machines comes to meet this requirement.
CNC sign making machines come in a variety of stlyes. Such as cnc wood router, laser engraving and cutting machine, cnc plasma cutting machine etc.
The signmaker could creates the design to CNC programs, then edit in the PC, output as the code which cnc control system could read. CNC wood router use cutting tool to remove material from workpiece for the sign making, mainly used in furniture, mold, sign etc.
Laser engraving and cutting machine operate on the same principal as cnc machines. The difference is the way removing wood in the sign makingn progress. Laser machines turn the wood into a puff of smoke. A constant stream of air blows the smoke away or you may use fume extraction for environment protection.
CNC plasma cutter cut metal material plate by the energy from power source.
Sign making machines allow reproduction of wood signs with minimal expense of precious man hours. Once the program is set, you easily duplicate the wood signs on cnc wood router.
Sunny Sun http://www.omni-cnc.com
Email: sales@omni-cnc.com
