Which One You Choose When Cut Acrylic? CNC Wood Router Or Laser Cutting Machine
2012-05-09 10:07:58 Browsing times:1
Which one you choose when cut acrylic? Saw or CNC Wood Router Or Laser Cutting Machine
If you do not value efficiency, you can use prcision lawyer to cut acrylic.
Well, now people could complete the work efficiently because time is rather valueable. This is the reason that laser cutting machine or cnc wood router is more pupular. People use computer to make the design, transfer the working command to machine, then the machine complete the work fast and efficiently.
What ever cnc wood router or laser cutting machine, when they cut acrylic, they can make the cutting edge be smooth, not like the sawyer. After you cutted the acrylic with cnc router or laser cutting machine, you do not have to polish its edge. It can save your time and cost.
Sunny Sun http://www.omni-cnc.com
Email: sales@omni-cnc.com
