Omni 1325 with Syntec controller / Vcarve pro
Results 1 to 4 of 4
Thread: Omni 1325 with Syntec controller / Vcarve pro
    Jun 2015
    Default Omni 1325 with Syntec controller / Vcarve pro
    Hi All
    I was wondering if anyone has experience of modifying the post processor to turn on and turn off the Air blower and vaccum. I think it may have been discussed before but couldn't find anything on search.
    Thanks in anticipation.
    Aug 2009
    Default Re: Omni 1325 with Syntec controller / Vcarve pro
    If the controller is set up to turn them off with m codes then it is easy. If its not, then the syntec plc ladder needs editing and I've yet to figure that out. I got an editor from syntec but it doesn't recognize the file. I've just been curious so I haven't spent a lot of time on it.
    You should be able to test m codes from MDI mode.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Aug 2009
    Oh, I did get omni to edit the ladder for me at the beginning to do this (vacuum and dust via my codes) as it was in my specs but I haven't succeeded on my own yet.
    Jun 2015
    Hi Graham
    Yes Ive had a quick try with the MDI but I may be using wrong codes, I tried M7, M8, M9?
