Is the Xpod inserted OK? it has ceased to respond...
Results 1 to 9 of 9
Thread: Is the Xpod inserted OK? it has ceased to respond...
    Dec 2016
    Iceland
    Default Is the Xpod inserted OK? it has ceased to respond...
    Good day, I have a Mach3 connected to a motion control card-MKX-V in my Omni Cnc machine and everything worked well untill now. The machine randomly stops and mach3 gives me this error message: "Is the Xpod inserted OK? it has ceased to respond" I have not changed anything and this suddenly starts and this has ruined many christmas projects that I have had going.
    So I have checked all earth/ground connections,
    I have tried to shut down everything else in the workshop except the pc and cnc machine so its not noise in the electricity.
    I have changed usb cables,
    I have put extra Ground wires,
    restarted many times,
    i have run many different codes and it just stops randomly.
    I can press reset and turn the spindle back on and continue but sometimes the machine "moves the part!" and mills on wrong places..
    It even stops when Im manually moving the machine. what could be the problem?
    could it be the software? or the control card..
    all the best from Iceland,
    THOR
    Dec 2016
    Iceland
    Default Re: Is the Xpod inserted OK? it has ceased to respond...
    Should this post be somewhere else? should i attach pics?
    Feb 2017
    Myanmar
    Hi Friend
    Do you solve the problem? Is the Xpod inserted ok?
    I also got same problem as you and looking for solution.
    Please share me if you solved the issue.
    Thanks,
    YeNyi
    Member dharmic's Avatar
    May 2015
    I had a similar issue where, after a few hours of running, my machine (not an Omni) would throw this error and shut down whenever the spindle was started up.
    Turned out that the frame wasn't grounded. Grounding it - just clamping a wire under a screw on the frame and running it to a ground pin on the power board everything was plugged into - fixed it.
    Feb 2017
    Myanmar
    Thanks a lot. I will do it and see how.
    Dec 2016
    Iceland
    Quote Originally Posted by YeNyi View Post
    I talked to the ppl at Omni after going through all the advices that I could find in a few days on the internet. That Included grounding EVERYTHING back and forth.
    Then the ppl at Omni told me it must be the computure so I went on and installed win 98 instead of vista that i was running ( was running fine for some months before this happened)
    After that everything worked fine. Im not quite sure what happened in the first place but clearly some kind of software malfunction.
    And yes, the I bought my OWN Mach 3. licenced to me but not some random dude
    hope this helps
  7. #7
    Feb 2017
    Myanmar
    Same for me.
    It had been workings fine for months and problem come suddenly few days back. I also surf internet and followed some advises and suggestions, still not ok.
    I will try grounding tomorrow.
    Thanks a lot
  8. #8
    Feb 2017
    Myanmar
    Dear Fri
    Please let me share.
    My problem (Is the XPod inserted ok? It has ceased to Respond) was solved. Still not 100 sure about what is the root cause.
    I tried to isolate the problem.
    Hardware
    Change usb cable, check the usb port
    Ground the spindle motor
    Software
    Reinstall the Mach 3 and Driver
    Check the settings
    All not working.
    So, today, cleaned the CNC machine with blower, re-install the cables and wires. After that I test with new computer and it all ok.
    So, I change back to old computer I used before. It is also ok now. I was amazed.
    It may be because of some particles stuck on some wire connection cause the issue. I guess. Because I found the the spindle coolant pump on or off something stop the machine with same message.
    Anyway, thanks for help friend
    Ye Nyi
    The best preparation for tomorrow is doing your best today. H. Jackson Brown, Jr.
    Read more at: https://www.brainyquote.com/quotes/q..._inspirational
  9. #9
    Member Monte101's Avatar
    Oct 2019
    Hello,
    I wanted to just add a post to this because I had the same issues...
    I did everything that was suggested in the thread and in my case I was still having the issues.
    So after working on it for a full day I found out that the issue is comming from the control board. Note: I use the Mach3 Motion control board.
    There are 3 other reasons why you will get this error.
    1. If you are useing relays that are triggered from an out put you will need to check the amps thay are drawing. If you have more than one relay on a circuit it will pull too much and after a wile it will make the board register the error.
    2. If you only have one relay per circuit then check the amps it is pulling... if the relay is heating up or going bad it will cause this error to pop up.
    3. If the 24 volt psu is going out then it will spike voltage or the psu will loose amps over time powered on. In this case the unit will run fine for some time untill the psu heats up and starts to loose amps or voltage is not constant.
    I hope this will help anyone that is having this issue and give them alittle more info to find the problem.
    This is what I found while building a few cnc machine's.
    Happy CNCing!
