here is the PO - sorry some of the formatting might be off.
I did not just fire this off. I sent a draft first and got a proforma invoice (PI) back and then back and forth until I had the changes needed and the PI did not conflict with this (even though the level of detail on the PI is a lot less). BTW - as for the models of the drives and motors - as long as they are comparable I'll be fine. The spindle I'll be sticky on as I wanted a ceramic ceramic bearings HSD spindle as both my brother and I run 15 year old HSD's with ceramics and they still work great. I did ensure we agreed that this model was available and suitable first.
I think the biggest 'oddity' for Omni is the insistence on UL listed components and wiring labels. Let's just say we've had issues and it the wires aren't labeled UL it is a big potential problem under a worse case scenario (inspection). That added about 5% to the price.
Surrey Plasticworks Ltd.
October 14th, 2015
Purchase Order:
Working/cutting area: 1600mm (MINIMUM) x 3100mm (MINIMUM) x 300mm
Frame/Gantry: 8mm steel minimum, heat treated after welding for stress relief, painted. Frame with adjustable feet on frame for leveling. Machined at mating surfaces, shims of suitable metal material where required.
Controller: Syntec 6MD with Ethernet connection provided with english manual and technical support contacts. With hand wheel mpg control.
Working Voltage: 220v 3phase with Ground
Motor Drives/Motors: Yaskawa 1000w (SGDV-7R6A01A) drives and Yaskawa 850w motors (SGMGV-09ADC61). 2 motors on X axis, 1 motor on Y and 1 motor on Z axis.
Cabling/relays/switches: All cabling with shielded wires labeled on the sheathing of the wire with UL or CSA listings. All components,wiring, motors, relays and switches to be CSA or UL listed and labeled on the exterior of the part/wire.
Omron E-stops on both sides of the gantry and control.
Schneider Main switch on cabinet
All components are grounded.
Motor Reduction: Belt Reduction
Drive: `Taiwan brand Helical Rack and Pinion for x/y and German sourced ballscrew on Z
Rails: Hiwin 30mm (HGH 30CA) Linear Bearings on all rails
Metal/Rubber Wipers on all bearings.
Automatic oil lubrication of all bearings.
ATC: Carousel type 8 slots ISO 30 - auto tool calibration sensor
Spindle: HSD model es929-H6161H0822 (No substitutions)
VFD: Delta 11KW with english manual
Table: Phenolic vacuum table without T slot - 8 zone
Dust Hood: Gcode controlled with air cylinder.
Relays: Please provide one relay for UL/CSA listed 70A/220v 3 phase relay (vacuum pump) wired to and controlled by the controller via button and G code.
Spares parts:
4 x spare pinion gears
12 spare linear bearings
2 sets of reduction belts
Price: Sorry - you'll have to negotiate that yourself...
Payment:
30% via wire transfer on confirmation of purchase order conditions and confirmed pricing
20% via wire transfer on receipt of pictures of components, before installation. Specifically:
- Servo motors and drives (with model and serial # visable)
- relays and switches (with CSA/UL listing visible)
- wiring to be used (with CSA/UL listing visible)
- Spindle to be mounted (with model and serial # visable)
- hiwin bearings
25% via wire transfer on receipt of build pictures/video showing specifically:
Detailed photos of
- Assembly,
- machined surface on parts that will be bolted together
- Metal shims used where needed
- Interior of Cabinet,
- Overall Wiring layout
- Ground termination point
- CSA/UL labeling on wiring
- Servo drives and connections.
- Transformers
- 70 amp/220v relay
- Exterior of cabinet
- Syntec controller
- Portable MPG controller
- Linear motion system
- Details of belt drive system
- Bearings and rails
- Close up of Rack and pinion
- Table
- Size of table working area.
- Plumbing of vacuum table
- location of limit switches
- ATC
- Spindle model and serial number
- ATC carousel
- Confirmation of proper working voltage.
Video of test run with tool change, auto touch off, dust boot retracted on our machine (marked as such in the video). Confirmation of 1600mm x 3100mm working size on the table. Confirmation of square cuts on sample material.
25% via wire transfer on completion of loading into container with photos of pre shipping greasing and packing.
Delivery:
Machine to be ready for shipping within 35 days of order placement.
Other terms:
Surrey Plasticworks has the right to engage 3rd party inspection firms to check production before the goods leave China and before final payment is made.
No additional accessories/features will be paid for without prior authorization.
