Originally Posted by
ihavenofish
there is a catch to the 15" travel on the nm200 though. you can certainly make the table move that much, but the end of the table will be under the Z counter balance.
so anything 15" deep you put on the table either has to be under 3"-4" tall. main thing is, the table moves 15" and you have 15" spindle nose to column.
aparently some people have moved the counterbalance to get more room.
in any case, the machine is by default set up for about 11.75" y travel, and you have to adjust settings and limit switches to get more.
im not sure about the 24" either. the one i use is the old version and it gets 21.5". its probably just another point of adjusting to get more. khai will be able to confirm all this.
sadly the Z travel is what it is, since you cant overrun on linear rails.
