Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Novakon Systems
Novakon Systems Novakon Systems machines here!
Old 09-03-2009, 12:13 PM
Frogblender is on a distinguished road
Novakon coolant system: any good?
Howdy...
does anyone have and use the Novakon coolant system? Link:
http://novakon.net/16.html
I've almost got my NM-135 watertight/soundtight enclosure finished. In particular, I'd appreciate if anyone could comment on:
- thoughts on coolant pump longevity - does it look/sound like it'll handle many hours of operation? I've had bilge pumps seize on me at low hours.
- Does the pump&tank go in the bottom "closet" of the stand? If so, does the drain hole in the NM-135 pan clog up? It is only about a 3/8" hole, and seems to me it might be prone to clogging quickly.
Any thoughts would be appreciated!
Old 10-13-2009, 11:04 AM
D.. D.. is offline
D.. is on a distinguished road
I have the NM-200 with the coolant system. The gauge on the tank leaks bad and months pass with no replacement available from Novakon. The connectors on the pump and the cable going to the pump were completely different. I had to go out an find my own connectors and install them. No fasteners were supplied to assemble the coolant tray system. The pump does go in the cabinet below but the hoses are not long enough to reach. You will have to go out and find your own hoses.
D. Evans in Tucson
Old 10-20-2009, 02:34 AM
ihavenofish is on a distinguished road
D. Evans in Tucson
eep. im going to be helping someone instal their nm200 coolant system soon. ill get back to this thread and report any difficulties.
Diy Coolant System?? twocik Benchtop Machines 60 02-16-2011 06:40 AM
Coolant system BrassBuilder Benchtop Machines 12 02-07-2008 06:44 PM
vacuume coolant system DrStein99 Open Source CNC Machine Designs 19 05-05-2007 02:40 AM
Coolant System for X2 Mill Snakeoil Benchtop Machines 1 04-29-2007 12:36 AM
coolant system mtechserv General Metalwork Discussion 1 03-27-2005 01:09 PM
