| Novakon Systems Novakon Systems machines here! |
| Interest in Router Milling Heads for NM-200 and other machines. I am developing a router milling head for the NM-200. It would allow a Porter Cable 2-1/4 HP Variable Speed 3.5" body diameter router to be mounted in place of the stock milling head for use in woodworking and with small metal-cutting bits. The NM-200 has a top spindle speed of 3000-4000 RPM and tends to generate a lot of heat in the spindle bearings at higher speeds. The NM-135 has a top speed of 6000 RPM. Small metal bits and wood routing bits require higher RPM for the optimal speeds and feeds. With the attachment, speeds would be possible in the 10,000 to 27,000 RPM range. The target user of this attachment would be someone like myself who needs to cut some heavy duty projects at lower speeds with the stock head, but also occasionally machines wood or uses small metal-cutting bits such as 0.125" or smaller. This attachment would increase spindle speeds to allow greater feed rates and more efficient machining. I am building one unit for myself, but wanted to see if anyone else had interest in this type of attachment. I would be interested in working with someone who has an NM-135. My own machine is an NM-200, and was hoping to make one for the NM-135 as well. I would need information on how such an attachment could be installed on a 135. The attachment for the NM-200 would replace the entire milling head where it attaches at the circular mounting plate with the existing 2 bolts. I would be willing to share my CAD designs with an individual wanting to work with me on a 135 version, as well as perhaps build an attachment for them to test and keep when done. So feel free to contact me if you have interest in one (or more) of the following: A) Working with me to develop the attachment for the 135. B) Purchasing a ready made attachment for the NM-135 or NM-200 C) Purchasing plans (and maybe even the GCode) for building the attachment. THIS IS NOT an advertisement, there is nothing actually for sale at this point, just seeing how much interest there is in the attachment and/or plans. Thanks! You can reply here, private message me, or my email is cjones@cjjonesarmory.com
__________________ He is more machine now than man..... |
| I've ordered a Macro Tech air spindle, good for 30krpm, and fits into my NM135 existing spindle. http://www.macrotechnologies.com/hig...e_mini_mac.htm This kind of spindle has very little power compared to your 2HP router, but I need the RPMs for engraving. I thought alot about rigging a router (I even bought the Bosch 1HP laminate trimmer); one of the main problems is bolting the bosch to the side of the millhead would result in a 4" or 5" offset between the NM135's spindlecenter and the bosch spindlecenter - and a bigger router would be even more than 5". After I bought the macro spindle, I found this: TB-350S spindle from "Wolfgang Engineering" on ebay - half the price, 20krpm (although I'm sure you could coax it to 30k), doesn't require a compressor, unbelieveably good TIR. I'd have to build an NM135 mount for it, but it is short enough, and the NM135's Z-travel is tall enough, that I could probably mount it directly under the NM135's spindle. And again, this is a low-power spindle. With regards to your "NM200 spindle produces alot of heat in the bearings"... my NM135 did the same, but is has gotten _alot_ better after a few hours of run-in. (I plugged the mill into the wall through a wattmeter, so I can see the exact powerdraw). It now runs cooler to the touch, and draws alot less power than when it was new. Definitely better with age. Further, once the spindle warms up, the powerdraw drops alot. |
| Another project? In case your not busy enough, here's another project you might want to consider: Novakon tap attachment. Just like Hoss's: http://www.hossmachine.info/projects_8.html This is something I'd be willing to pay money for. Totally useful, totally simple. The NM135 (and NM200 too??) already has the 4th axis ready to drive the stepper. |
| Here is the first version of the router attachment. I was concerned the setup would be flimsy without being welded, but the bolted version works extremely well and is rock solid. If I were to produce this for sale, I would probably weld the parts. The router clamp needs a bit of refinement. I did not have a way to make a router clamping system like the original router base clamp. I want a springy clamp system that "grasps" the router rather than the bolt-together system. I had to carefully fit shims between the clamp halves to get the proper hold, not something that is user friendly, and could potentially damage the router if not done properly.
The VFD is controlled by Mach3 (through the C11G board from CNC4PC) by the 0-10VDC signal, but it's not exactly accurate. Ok, it's nowhere near accurate even with extensive tuning. It can be off by as much as a couple hundred RPM in some RPM ranges. WHen using the C11G board, Mach3 is configured to use step and direction pulses, the C11G board converts that to a 0-10VDC signal. The upper range of the signal is adjusted with a "pot" on the board itself. The VFD then interprets the 0-10VDC signal into an RPM. The VFD is very configurable as there are low-limits, high-limits, acceleration curves, etc... all configurable in the VFD. Very useful, but it seems like there is a more accurate way to control the spindle. The VFD has the option to be PID controlled, and Mach3 has the option to use PID control. I just haven't been able to figure out exactly what I need to get Mach3 and the VFD to communicate. Most of the trouble comes from the VFD's interpreted instruction manual. It's not to read well (if you catch my meaning). I believe that using the RS485 port on the VFD is the key, but I've been too busy to mess with something to interface the RS485 port and the PC. Sunfar sent me a copy of their PC Control Software, but it crashes and won't run. It was missing a dll or some other file needed. I really should ask them if they have an updated version.Alternately, I was trying to figure out if there was a way to attach a sensor to the spindle that would provide a positive feedback to Mach3 to be able to fine tune the spindle RPM, again, no time for research. Anyway, if I could get 100% accurate RPM, then tapping would be easy to do with the existing spindle. As a final alternative, (perhaps the most expensive alternative) is to buy or build a reversing tapping head, but there are problems there too. Back to the issue, maybe if people reading this thread see an image of the router attachment, they may be more interested. I am extremely happy with it's operation so far. The next step up would be to make an actual high speed spindle instead of the router. The prices of the aftermarket high speed spindles are much too high. I expect the router to live for quite a while, but it really isn't designed for hours and hours of continuous operation at speeds and forces that humans probably would not exert.
| Plus, the spindle almost certainly has inadequate (on the NM135, at least) torque at the low RPMs needed for tapping - indeed, my spindle won't even spin below 500rpm, cuz it ain't designed to. Anyhoo... FYI - Novakon sells cheap steppers that look like they'd do the job. Add a plate of aluminum, two cogs and a belt, and we're done.... |
If I had the NM200, and wanted more RPMs (6000, say), I'd consider the following: ask Novakon how much a replacement spindle costs, and if it's reasonable, order one as a spare, and change out your belt/cog ratio to give you 6k. If you cook the bearings, then you're out the cost of the spare. If you don't cook the bearings, then you've got a 6k setup (albeit at proportionally lower torque - but the NM200's motor is fairly beefy, so that shouldn't be a problem). |
To install the router assembly, connect up one of the quick electrical connections (the one with the E-stop), and install two bolts to hold it in place. The router power cord routes alongside the other wiring and plugs in to a standard outlet. No auto-on/off, but it's not that hard to remember. I suppose I could put a relay in there, but it's not a big deal to me right now.
#10
eep! cant believe i missed this - or maybe just forgot about it. mind if i borrow the idea to make a head to hold my colombo spindle? ![]() that would turn the nm200 into a pretty badass guitar milling monster. |
#11
#12
my plan for this is to have it take the colombo in both vertical and horizontal, and then put index pins on the swivel at common spots i use - like 2 degrees for milling neck angles etc. then i also have an R8 spindle shaft here that i was going to make a bearing block for and try and set up with a power drawbar for TTS, along with a servo drive to get a nice 3500/7000rpm spindle that can do rigid tapping and such. i think the reason there wasnt much interest, aside from there only being a handful of nm200/smithy/syil x6 owners, is because it not ideal to switch back and forth with the big head. with the small r8 block i think it might become alot easier. i got the spindle shaft for like $50 from weiss. its the same one thats in the grizzly g0704. decent AC bearings to fit it run under $100 at vxb.com. the servo is at machmotion with drive for about $650 (1hp continuous, 2hp intermittent). |
| Is anyone familiar with a LUX milling machines? | garagefela | General Metalwork Discussion | 0 | 06-10-2009 02:49 AM |
| MANUAL MILLING MACHINES | JMECKES | General Metal Working Machines | 0 | 06-01-2009 08:41 AM |
| Just IN- New and Used Milling Machines | findamachine | Product Announcements & Manufacturer News | 0 | 09-03-2008 12:23 PM |
| Conversion to programable independant heads for Gantry Twin head router table | ohallock | DIY-CNC Router Table Machines | 0 | 04-18-2006 07:20 PM |
| Heads Up - Article about building CNC Milling Machine | samualt | CNCzone Club House | 3 | 06-13-2005 03:43 PM |
