| Novakon Systems Novakon Systems machines here! |
| Novakon Mach3 XML Needed Hi All, I am trouble shooting a problem with the spindle speed control on my NM-135. It's a Revsion 2.1 but I think the Revsion 2.0 also use the PWM spindle control. We, that is Novakon and I have been swapping boards and cables so I'm thinking it could be in the Mach3 config settings. Unfortunately I didn't back up my working XML file and would like to see someone else s for comparison. The other night, I did a spindle calibration in Mach3 and since then the spindle goes in forward/reverse but only at full speed. Any input or current working XML's would be greatly appreciated. Thanks, -Greg
__________________ "If Necessity is the Mother of Invention, then Who's the Father?" |
I can get you my 2.1 xml later today. I was fiddling with mine - I had to set the PWM base frequency (Config->Ports/Pins->Spindle) to 1000Hz (which contradicts the mach3 documentation, which says set it around 5 or 10, and caused either off or fullspeed spindle operation for me) and min freq to 0%. After that, gcode "S" commands seem to work, numbers between S800 and S7000 will change the speed (S7000 will run the spindle faster than S6000, despite it being a "6k spindle" ). I don't have a tach to calibrate though.I have to CD300 (cheapo) controller. |
| Frogblender, We have been testing at the hardware level for a variable voltage from 0-to +5 going into the motor speed controller and only coming up with +5 only which means full speed. I figured, hey, we tried everything else, it must be software. There's a lot I don't understand about Mach3 especially when it comes to the PWM part. I have backed up my xml and will try your suggestions. Thanks, -Greg
| Since the last post here, I've ordered a tach (tachs are nearly free on ebay); when I get it I'll do some calibration. What controller do you have? |
| I have the CD-100 the comptroller. The base freq was already set to 1000 and the minimum 10 so I changed it to 0 and got the same full speed condition until I tried an s900 which dropped the speed to about 1/2 to 3/4 of full. Any other S calls seem to have no effect. -Greg
I don't think mach3 knows I have a 6k spindle, and therefore won't know, for example, to put the dutycycle at 50% for an S3000 instruction. When I get my tach I'll check. |
| Frogblender, I kind of understand the square wave thing you mentioned and that analog voltage would not make sense, but I had John on the phone yesterday and was told to check the voltage across a couple of pins on one of the connectors inside the machine. He informed me that, as I move the RPM settings, I should be getting a variable voltage across those two pins. Go Figure
| Hey, this is really crazy! I tried yor suggestion and it seems to operate narrowly in the 900 rpm range but when I go to lets say, 910, it lowers the speed rather than raising it. At least there's progress. I have been fighting this for days now.
| As I mentioned eariler, I did a spindle calibration last week and, on completion, it must have made some changes in the settings. Where, I don't know. When I look at the motor tuning settings for spindle, it makes no sense to me. The graph line is off the chart so to speak.
#10
You might also want to check the pulleys menu - min speed should be 0, and max speed should be high (25000 should be ok). |
#11
| Thanks Frogblender, Will try that. -Greg
#12
| Frogblender, Tried that and no improvement. In fact it went back to a full speed condition. I have a funny feeling it's a corrupted xml or a problem somewhere else in the config. -Greg
| Has anyone seen a Novakon mill | tbas | Novakon Systems | 13 | 07-06-2010 08:47 AM |
| I Have a Novakon NM-200. Questions anyone? | cjjonesarmory | Novakon Systems | 21 | 11-09-2009 05:18 PM |
| Novakon | williams480 | Novakon Systems | 15 | 05-14-2009 10:09 PM |
| Just IN- Novakon NM-135 (Rev. 2.0) BenchTop CNC Mill | Novakon | Product Announcements & Manufacturer News | 0 | 01-25-2009 08:45 PM |
| Help needed to customize output of Mach3 | frenzal | Screen Layouts, Post Processors & Misc | 4 | 10-15-2006 09:25 PM |
