Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: nm070 test video
    Jun 2007
    canada
    nm070 test video
    so i mounted a webcam inside the housing for monitoring with the doors closed. the app can record so i did!
    quality is poor at best, and only 16fps, but its nice and convenient for the moment until i get my HD setup somehow.
    anyhow, this is a boring video, just ran the circle pocket macro in some maple. this is a second run in the same pocket, first one was covered in chips so you couldnt see what was going on.
    i used a dull 3 flute m42 1/4" end mill. .25" depth, .12" stepover, 60ipm. the cut runs at 100ipm with a propper 2 flute end mill meant for wood. it worked rather perfectly and didnt even make much noise inside the cabinet.
    going to do a steel part possibly tomorrow if i have time.
    "http://www.youtube.com/watch?v=cFVPZtmcRyw"]YouTube - kx1 circle pocket test
    Jun 2007
    canada
    and the first real part:
    hmmm... anyone notice the mistake?
    i hand coded this thing and of course i had to screw it up. on the bright side, the machine can rip through 7/8" of maple at 50ipm without any lost steps.....
    i took a video, but ill wait til tomorrow when i do it again sans coding error. these are guitar pickup rings in quartered hard maple if anyone is curious. they will be cut with a pull saw into 2 or 3 rings per stack. i can get about 5 stacks on this side of the block, and leave the other side for some fretboards.
    cutting maple is also a little noisy. lots of vibration, but with the enclosure its still not much above normal speaking volume. i doubt the neighbours can hear much more than a quiet buzzing.
    Registered fourwheeler's Avatar
    Dec 2006
    It doesn't look too bad man, a little wood putty and you are golden.
    Jun 2007
    canada
    almost done the program, just needs a finish pass on the outer shape and chamfers on the edges. this is lignum vitae.. hardest and densest wood on earth. resawing this 25"x3" board ate one bandsaw blade. ironically, with my m42 3 flute aluminium cutting end mill this was actually smoother and gave less trouble than the maple. i think its because the wood is extremely waxy and lubricates the tool.
    im going to cut the sides off and then flip it and mill the backside off. that seems to be the best way of dealing with the remaing stock. the maple i just buzzed down with sandpaper, but lignum vitae does sand well at all.
    Jun 2007
    canada
    some fun with a fly cutter in 6061. worked rather well. nice to see since my flycutting in steel has been a bit of a failure thus far.
    "http://www.youtube.com/watch?v=5rdVMLpL_Lg"]YouTube - kx1 flycutting 6061
    Jun 2007
    canada
    so i had some fun with aluminium, worked great. flycut with a c2 carbide tool.
    milled a pocket with an m42 3 flute end mill. also worked great. i think i know what settings are good with these and they work as i expect them to.
    stainless steel im having bad luck with. i cut some 304 stainless with a 5 flute coated carbide end mill. i think i had my speeds and feeds in good territory and it wored flawlessly for a few cuts. but i managed to chip the cutter teeth, and well as the edge of the flutes on a stide cut. not entirely sure how it happened. i was using a spray of coolant every few seconds on this test, perhaps it required flood?. anyhow, $28 wasted. carbide seems very fragile, i think ill only use it for aluminium from now on.
    also not doing so hot with 1018. seems to mill fine with the m42 end mill, no coolant, 5k rpm. havent yet found a setting for fly cutting though that doesnt kill the tool in minutes.
    blah!
    well, at least im having fun!
    edit: well, i think i know how the 5 flute end mill broke. the tools says 350sfm is moderate load... i had 327. that was fine. says .0005 feed per tooth, i had .0008, which isnt stupid, but combined with my "mistake" it probably helped kill the tool. the end mill is designed for shallow side cutting "only", and my program (a pocket) started with a 1" long full width slot before it got into side cutting. the side cutting was also 60% of the tool diametre, which according to their data needs the suface speed derated by half and isnt really recomended. this was my mistake it seems.
    so there you go: how to kill an enxpensive endmill by making a bad program.
    oddly, id bought this tool to mill some O-1 tool steel, and the speeds, feeds, stepover, depth i used would have matched perfectly as long as i got rid of any slotting.
    ... im still having fun though
  7. #7
    Jun 2007
    canada
    so after some consultation with the man at the tool store (who coincidentally runs a syil x4 at another shop), ive determined a few things.
    with the right feeds, speeds, diametre and tool the nm-070 and flycut aluminium with ease. does a spectacular job in fact. ive got the cutter at 1.75" 5000rpm and 15ipm with a .005" depth per pass.
    i also learned that 304 stainless sucks, and the tool i broke should work if i am careful to keep it within spec. 303 is the way to go if all i need is shiny and not specific performance.
    sadly, we also determined that the nm-070 cannot flycut steel. why? because the spindle speed needs to be 300-600rpm or even lower for optimal performance and at that speed - while the machine does have enough torque to cut, it does not have the rigidity to deal with the hammering of incremental cutting.
    i also learned that if you use a tool in steel, its a steel tool... cant reuse in aluminium because the edge is dulled. that and i got a few tips on regriding all these poor cutters ive ruined! yay!
  8. #8
    Jun 2007
    canada
    successfully flycut some steel. finish is not great due to vibration, but the surface is flat and the tool lived well enough. i dont think ill be doin that often though.
    "http://www.youtube.com/watch?v=Cw0zHDuxQk4"]YouTube - kxt1 flycuting 1018 steel
  9. #9
    Jun 2007
    canada
    yay, i made something useful. its a clamp for my new 2" tool makers vise. i did this one in jog mode. now i need to write a program now to cnc 3 more.
    im a bit puzzled how to part them off. i could turn it sideways and mill them off, but thats a bit of a waste of material. i imagine a slitting saw is the ideal way, but i havent got one handy. could bandsaw them and then do a clean up pass - but my bandsaw is a bit crap for metal. hmmmmm.
    thoughts?
    also, i statred the job with an m42 3 flute cutter. it worked well enough, but started to overheat doing the deep slot, and eventually died trying to plunge the hole. only did the hole cause i knew it was near dead anyway. so i switched to a carbide 2 flute end mill. what a difference! the finish on the side cuts is amazing, chips come of silver, runs slightly faster feeds and seems to actually deflect less on deep side cuts giving a near mirror finish. we'll see how it holds up now on the next 3.
  10. #10
    Jun 2007
    canada
    description in the image. video soon.
  11. #11
    Jun 2007
    canada
    "http://www.youtube.com/watch?v=iWvmGCY0ofI"]YouTube - kx1 cnc milling vise clamp in 1018 steel
    its interesting to look at the video. in the slotting operations, chips are blue/black. in the side cutting silver. i think i need to redo the slotting g code with a lower rpm. the slotting is probably whats dulled the tool somewhat quickly - that or the fact that it was $11 cheapo cutter..
  12. #12
    Dec 2006
    The K1 appears to cut steel pretty well.
  1. housing on the cheap for the nm070
    By ihavenofish in forum Novakon Systems
    Last Post: 04-26-2009, 09:30 PM
  2. How do I post a video in the video section?
    By CNCadmin in forum CNCzone.com FAQ
    Last Post: 01-13-2009, 09:39 AM
  3. New Ceramics grinding Test on CNC video Forum
    By Astonlee in forum General Metalwork Discussion
    Last Post: 11-14-2008, 03:56 PM
  4. This is a test thread in the test forum
    By adam.faris in forum Test Forum
    Last Post: 10-27-2008, 12:21 AM
  5. Video streaming from youtube test post.
    By ynneb in forum Test Forum
    Last Post: 02-22-2007, 06:10 AM
