Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Novakon Systems
Novakon Systems Novakon Systems machines here!
Old 04-24-2009, 12:10 PM
ihavenofish is on a distinguished road
sample item.
im going to be making an "example" item on my nm-070 (sieg kx1) mill over the weekend and filming it. the intent its to give a good representation of how the machine performs. theres very few videos of these machines, and the few that there are are not really representative of the machines abilities - novakon's own nm135 demo for example.
ill be using a small block of steel (1-7/8" x 6" x 7/8") for this, and will be making a shape that will have straight lines, perpendicular lines, circles, curves, paralell diagonal lines and a flat top and bottom. things that can be mesured after its made to check accuracy, finish, etc.
the plan is then to get it tested on the nm135 and nm200 and make the gcode and setups available.
so this is all well and good, but i had an idea. rather than make a pointless bunch of cuts, i think i should make the file some sort of object thats usefull on all the mills. something for example that a nm135 owner would want, and can run the code to both test their machine, and also get a useful part.
i dont really have any idea what would be a good item though off the top of my head. i thought of things like clamps, but they are much too simplistic for the test/video. likewise i had thought of a spindle clamp for a dremel or proxxon, but it couldnt be universal to all the machines and would need a much bigger steel or aluminium bar to make.
any bright ideas?
Old 04-24-2009, 04:51 PM
TacPyro's Avatar
TacPyro is on a distinguished road
Make a spindle flood coolant block for the 135. The idea behind the block is to cool the spindle and allow for much more convenient coolant distribution to the tool. Generally the shape of the block is the shape of the bottom of the head where the spindle exits. Of course there is a hole in the middle where the spindle resides.
Design the part so that coolant could be pumped in from the sump, through the coolant block where it would collect heat from the spindle, and out through a number of lockline that surround the perimeter of the block.
Confused yet?
-Blane Nelson
www.tacticalpyrotechnics.com
Old 04-24-2009, 06:40 PM
Confused yet?
not confused... but uh.. i get the feeling thats not gonna be 1.875" x 6".
that and it should work with all 3 novakon machines. i dont have an nm135
Old 04-24-2009, 08:18 PM
williams480 is on a distinguished road
How bout' a simple touch off block, which could house a cheap dial indicator.
Just a thought....
Old 04-24-2009, 08:24 PM
marcel beaudry's Avatar
marcel beaudry is on a distinguished road
Hello
how about a T nut slot cleaner
Marcel Beaudry
Old 04-24-2009, 10:34 PM
Just a thought....
i was going to do an electronic touch block for use with mach. its going to be made form round stock though and done with a turning operation in the spindle. ill probably release the code for that and a video too, but it wont be for a little while.
as for a t slot cleaner... every machine has a different size is one issue.. the second is.. i dont know what that is! is it just a shape that you cram through the slot to knock out chips?
im looking at the thinks i personally need for some upcoming jobs, and they are mostly clamps, riser blocks, and such.
i do have to make some modification parts for the machine, but they are too specific for this example. im porbably gonna video everything i make though.
for this weekend however, all i have is 1/4" end mill, a fly cutter and a small block of steel.
Newbie- Just created my first item in Onecnc Moulder OneCNC 1 03-29-2009 06:17 AM
Harbor Freight 15% off one item coupon tooManyHobbies Benchtop Machines 7 05-12-2008 10:51 AM
N00b question about EBay item mrogowski Linear and Rotary Motion 5 03-18-2008 08:01 PM
milling lip around bottom of item BrassBuilder Dolphin CADCAM 24 03-12-2008 09:24 AM
New Sub-Forum Item ltmquik General CAM Discussion 1 02-02-2007 08:27 AM
