I own a Novakon NM-200 Series 1 with the yellow box that had the C300 VFD unit go bad. Not being a good electronics person myself I have hired an electronics tech to fix my machine. I found a C300 locally and have it already wired up ready for the tech to come set all of the parameters for me. Since I don't know if the old VFD will still power up so he can get the parameters off of it could I ask if anybody has a list of the factory settings for the Series 1 VFD? If nobody has such a list does anybody have an idea as to where I could go to get a list of the settings. Thanks
I've still got a working C300 in a machine, but frankly, some time ago, I jumped in and made whatever changes I needed at the time to make it run the way I desired.... I was converting the machine from Mach3 to Flashcut because one of the problems was exactly that of having a reliable spindle control.
I only recall that I set the thing back to defaults and worked my way into what I wanted. I did find a PDF manual for it, tweaked up on my foreign language and had at it.
I think it would take me a bit of time just to get it back into programming mode just to look !
I will look in my folder for that machine tomorrow though to see if perhaps I had written things down or not.
Chris L
