yeah, the new site seems to be messed up a bit still.
the machine uses steppers and an indcution motor for a spindle. you have to supply a computer which is the control (or buy one from novakon).
on the old machines, it would have come with mach3. i would assume the new one is the same, but i dont see it mentioned explcitely. mach 3 does NOT support rigid tapping, however with careful testing, you can make use of a compression(floating) tap holder and use g84 to tap. you woul dneed a servo spindle motor and emc2 on linux to do proper rigid tapping, although people have found some clever ways for mach3 to do it as well (still requiring a servo).
hopefully they get this all onto the website again, it was all there a few weeks ago.
in any case though, if you need to know specs, just email them. its alot easier than ranting on a forum about it
