Results 1 to 3 of 3
Thread: novakon nm 200 x axis not responding
    Mar 2011
    Hi folks, I'm a total new-be with cnc mills .
    I was doing some mach3 wizard text engraving and everything was going fine, I shut off the machine and the next time I turned it on the x axis would not move.You can see the numbers changing in the dro but the axis won't go anywhere.
    What am I doing wrong?
    Jun 2007
    canada
    Quote Originally Posted by celodoy View Post
    check all the cables, make sure nothing has come loose. look inside the computer cabinet at the gecko drives and see if any of them have a red light.
    Buy A Kitten!!!
    Mar 2011
    Quote Originally Posted by ihavenofish View Post
    Hi, yes I checked the cables and they all seemed to be firmly attached but I do see a red light on the gecko marked as x axis.
  1. Need Help!- Artcam not responding
    By ronateah in forum ArtCam Pro
    Last Post: 10-10-2012, 02:32 PM
  2. Need Help!- Z-Axis isn't responding properly...
    By capth00k in forum Mach Mill
    Last Post: 01-26-2012, 06:54 PM
  3. Novakon NM-200 - Z-axis problem
    By adam1071 in forum Novakon Systems
    Last Post: 06-11-2011, 11:31 PM
  4. engraving not responding- please help?
    By ral72 in forum CNC Machining Centers
    Last Post: 10-01-2010, 06:50 PM
  5. Need Help!- Cambam not responding
    By joshuadri in forum CamBam
    Last Post: 06-22-2009, 03:54 PM
