Results 1 to 5 of 5
Thread: AutoTool Zero code for MACH3
    Feb 2009
    Smile AutoTool Zero code for MACH3
    Gang, Here is useful code which I have tested to do the auto tool touch off:
    [url=http://www.cooperman.talktalk.net/index.htm]
    Click on the tool setting button, then scroll down to the Tool setting Z description and button code for MACH3.
    All you need with this is a touch probe with a known height, with the connection fed into pin 15 on the NM-145 Breakout board screw terminal.
    Connection details to follow.
    Steve
    Feb 2009
    Quote Originally Posted by steveb946 View Post
    Connection details--
    Steve
    Due to the non-osolated electrical input to pin 15 on the BOB, the probing is erratic due to electrical noise.
    This needs to be corrected by adding an opto-coupler between the probe and pin 15. I will post a schematic if anyone is interested.
    Registered MRM RCModels's Avatar
    Jul 2007
    Steve
    Please do. I have a 200 on the way, but wiring should be similar.
    Feb 2009
    AUTO Tool Zero in Z
    Here is the schematic for the isolated probe circuit. There are only four electronic components. Just solder them onto a small Radio Shack perforated board (with solder pads on the back side). The cabling from the electronics must be shielded all the way out to the probe location.
    Attached Thumbnails Attached Thumbnails AutoTool Zero code for MACH3-touchplate.jpg
    Feb 2009
    I forgot to add the pin numbers to the 6-pin opto isolator:
    Input anode-LED = pin1, Cathode= Pin 2
    Output collector= Pin 5, Emitter = Pin 4, and pin 6 = No connection.
    1. Newbie- G-code generator for SW and Mach3
      By WoodMizer in forum Mach Software (ArtSoft software)
      Last Post: 05-06-2010, 02:10 PM
    2. g code mach3
      By eloid in forum DIY CNC Router Table Machines
      Last Post: 10-05-2009, 09:08 AM
    3. mach3 g code format
      Last Post: 08-20-2009, 11:25 PM
    4. Need Help!- BOBCAD V23 Code for Mach3
      By adel_acameron in forum Mach Mill
      Last Post: 03-22-2009, 04:25 PM
