Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: Looking to buy NM145
    Dec 2009
    Hi guys,
    I'm still on the fence about whether or not to buy a NM-145 while they are still in stock.
    The concerns I'm having are about learning the CAM and mill control software. I had a college class in CAM a several years ago, but it was using MasterCam and I honestly don't remember too much from it.
    The other concern is, is the mill itself going to be a hobby to keep it running smoothly, or does it work often enough to produce parts.
    I know you guys are biased, since if your in this forum you've probably already invested in a Novakon machine, but I just want some reassurance that I'm not wasting any money.
    Thank you!
    Dec 2009
    Also, can anyone tell me if it is possible to over travel the X axis to drill holes on 15.300 centers?
    Thank you
    Feb 2009
    X-travel
    Quote Originally Posted by aucran View Post
    Thank you
    I measured about 14.5" max X-travel without hitting the hard stops.
    This is a very well designed machine--especially the electrical system with the newer Spindle Motor driver and the Sinusoidal drivers for the stepper motors. I furnished my own computer system board, power supply and hard disk and Novakon kindly provided the proper mounting plate. This means that I have local warranty support on any of the computer parts.
    Expect that upon delivery, you will need to partially disassemble the X & Y-table to clean and inspect the moving parts. Especially, you must verify that the one-shot lube system is working to supply oil to all the parts.
    Shipping damage is quite possible. I was very fortunate, since Novakon used a super-careful exporting shipper called Polaris Transportation 1-800-409-2269. The local delivery here in Tucson Arizona was DATS trucking (with lift gate for residential delivery) , also very good at handling such heavy machinery. Get some EXPERIENCED help with machine rigging to safely uncrate and place the machine.
    Jun 2011
    There isn't really any easy way to increase the X travel, in the cursory look I had, you could probably increase Y trave, but it'd require changing the ballscrew and the axis cover.
    The crushed X axis oil line seems to be a common issue, there is no stop to prevent it becoming crushed when the axis hits the end of travel. Novakon suggests replacing one of the ballnut mounting screws with a longer bolt and a lock nut to act as a stop.
    The electronics seem well put together.
    If you provide your own computer it's important to know that the Mach configuration on Novakons website is (or at least was) completely wrong. Once corrected I could run rapids at 150IPM easily (probably considerably more).
    Mine did get damaged in shipping, the PSU mounting board in the electrical cabinet shattered (probably due to a drop), damaging some wiring.
    Novakon does run them prior to shipping and mine came with attached measurements which are pretty close to what I measure, so there is an inspection process.
    Mine was surprisingly accurate out of the box backlash of 0.0005 in X and no measurable backlash in Y.
    I don't run mine for production, so I can't comment.
    Jun 2007
    canada
    Quote Originally Posted by rpovey View Post
    There isn't really any easy way to increase the X travel, in the cursory look I had, you could probably increase Y travel, but it'd require changing the ballscrew and the axis cover.
    absolute max travel on the x is shy of 15" if i recall. getting more than that is possible if you altered the free end bearing mount on the ball screw giving it clearance.
    the y can run out to 11" of travel stock with the guards removed, however you only have a little over 9" from spindle to dovetails, and of course without the guards, you have to be careful of debris getting in everything.
    Dec 2009
    thank you for all the information guys.
    After a few emails back and forth with Khai, I feel a little more confident now.
    The restriction on the X axis is something I can work around, probably make a jig. Its just a hole pattern, so I think I should be fine.
    The stated work envelope still works for everything else I'm planning on. So with the sale, I think I'm sold.
    Thank you guys, I'll probably be back with more questions and problems .
    Feb 2009
    How is your mill order coming? Keep us up to date here, and there are quite a few great helpers to answer your questions!
    Steve
    Dec 2009
    Hi, still waiting on it actually.
    Khai said it would be about 4weeks then he said they were running a week behind.
    I'll email and get an update.
    I did ask for extended wiring on the cabinet so I could mount it to a wall, so if they only had a few left and finished, they may have had to rewire the whole thing for me. Which is fine for now, I'm still cleaning my garage.
    I'll update this again when I get it.
    Dec 2009
    Hi all, I got my mill in and set up. So far I've only used Mach to do some drilling and facing but everything looks like its running.
    A couple of problems on arrival:
    The Right Angle fitting to the coolant pump was broken. John promised me a replacement so all will be fine here.
    The Pin that keeps the R8 Collets from rotating in the spindle is oversized. I have some old collets with the slot ranging from 0.150-0.190" and I'm guessing my Pin is 0.163 or so in diameter. John's recommendation was to remove the Spindle and grind the pin down to spec. Not fun, but doable. Is this pin really needed, could I just remove it? I seem to remember a post on the IH forums that they said the only thing taking out this pin will do is make tool changes a little bit faster. Can anyone confirm this?
    What type of coolant is recommended? I'd prefer something that doesn't mind sitting for a few days if possible. 90% of my work will be on AL6061, with the rest brass and steel.
    What CAM software are you using, if you opted to provide your own PC?
    Thank you.
    Jun 2011
    I like CAMBAM for most simple parts.
    Feb 2010
    For CAM software, check out VisualMill. It's really easy to use and has great instructional videos.
    The $4000 price seems like a GREAT deal. Do I remember seeing that the closeout price carries NO warranty however?
    Are these zero backlash screws on these machines? I have a LMS X2 type CNC mill right now but the .005" backlash is driving me nuts.
    Dec 2009
    I haven't tested mine yet, but I remember reading one of the older threads in this section (while researching) that someone measured >0.001 backlash.
  • Page 1 of 2 12 LastLast
    1. my take on a nm145 enclosure
      By t300 in forum Novakon Systems
      Last Post: 09-10-2012, 09:47 AM
    2. Revised VFD for NM145
      By cteufert in forum Novakon Systems
      Last Post: 08-21-2011, 08:08 PM
    3. more trinkits from the nm145
      By ihavenofish in forum Novakon Systems
      Last Post: 07-23-2011, 02:23 PM
    4. my new nm145!
      Last Post: 12-20-2010, 11:05 AM
    5. New to the forum and NM145
      By tunaahelper in forum Novakon Systems
      Last Post: 02-27-2010, 02:01 PM
