I have a NM-145 and don't know if the oil lines are the same but on my machine they are 5/32nds or 4mm nylon tube. The compression fittings are available from Lube Management Solutions | Oil Analysis Services | Trico Corporation as are the oil metering valves and other parts. The tubing should be available from any place that deals in pneumatics.
LinkBack URL
About LinkBacks
