Results 1 to 3 of 3
Thread: Ballscrew not served by oiler: how to lube ???
    Mar 2009
    After much checking of the plumbing, it seems the Z ballscrew of my nm135 is not serviced by an oiler line.
    Odd, because all 6 millways and the X and Y ballscrews all have oil lines.
    Anyhoo... I guess I never noticed the Z ballscrew non-oiling because often I manually oil in liberal quantities. But now that the machine is in its full enclosure, it is difficult to access the Z ballscrew.
    So.... what kind of lube should I use on the Z ballscrew? Grease? Oil? Ideally it would be a lube that can last, say, 50 hours of operation before needing re-lube.
    Dec 2003
    Usually something like Vactra2, Waylube.
    Dec 2006
    I like Vactra a lot - it's just tacky enough to stick while not so sticky as to glue on swarf. Pretty nice all around.
  1. Need Help!- re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 01:49 PM
  2. NM135 Oiler on Z ballscrew??
    By Frogblender in forum Novakon Systems
    Last Post: 10-12-2011, 11:39 AM
  3. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-18-2010, 11:21 PM
  4. Changing lube on a ballscrew
    By Guldberg in forum Linear and Rotary Motion
    Last Post: 06-19-2009, 09:55 AM
  5. Ballscrew grease/lube/oil? Yeah, seriously.
    By cnczoner in forum Linear and Rotary Motion
    Last Post: 05-08-2009, 02:21 PM
