Results 1 to 8 of 8
Thread: Spindle speed incorrect Mach3
    Dec 2009
    Question Spindle speed incorrect Mach3
    I just received one of those inexpensive laser tachometers and used it to check the actual NM200 spindle speed vs. the Mach3 command. The speeds are off a good bit, as I knew going in. At this time, a mach3 speed of 500 reads over 1200 on the tach, and each increase of 100 RPM in mach3 increases the spindle speed by 270 rpm. The VFD display shows numbers close to the tach, and I have been adjusting the mach3 speed in the past so that the VFD shows the speed I want.
    Does anyone with a series 1 NM200 have correct speeds via mach3, and if so will you share your XML, or a screenshot of the spindle motor setup screen.
    Registered cteufert's Avatar
    Jan 2011
    I don't have a NM200 but I do have a NM145 with similar speed issues.
    I have played around with the VBScripts in Mach3 and found the one that sets spindle speed. As is it requests the speed the user wants and outputs it to the machine. I was able to make a minor change to bring my speeds more in line by inserting a line between the two that are there:
    RPM = RPM * 0.8
    My speeds are rough guesses since my tach stopped working 1/2 way thru testing and I haven't replaced it yet. Based on your numbers I suggest the following:
    RPM = RPM * 100 / 270
    or
    RPM = RPM * 0.37
    Charlie.
    Visit [URL="http://www.shadowspawnllc.com"]http://www.shadowspawnllc.com[/URL] to see what enhancements I have available for the NM-145.
    Dec 2009
    I'll try that, thanks
    Dec 2009
    The VBScript worked for me. Thanks!
    Something to be aware of is that this translates the S code, but it's the translated code that shows up in the spindle speed DRO. So if I put 1000 in the DRO and start the spindle via the button, the spindle will be turning at 2680 (my ratio in the script is 2.68). Similarly, M3S1000 will turn the spindle at 1000 but display 373 in the DRO.
    Jan 2011
    Glad to hear the tip to modify the VBScript worked out for you. There is most likely a way to muck around in the Mach3 screen set to change the scale of the DRO but I haven't looked in to that area as of yet.
    I was able to get the spindle speeds to be more accurate on my NM-145 with a different change. Instead of highjacking this thread I will start another.
    Charlie.
    Quote Originally Posted by kvom View Post
    Dec 2009
    The DRO issue isn't a biggie, as I normally will just enter 400 for edgefinder use; otherwise the g-code will control the spindle.
    Registered bob b's Avatar
    Nov 2010
    united states
    spindle speed also wrong
    my spindle does not even come close i have to run mine 600 to get 300 i do not understand why this was not set when they checked out machine
    Dec 2009
    Quote Originally Posted by bob b View Post
    It would be nice to understand how the VFD/Motor are controlled. Is it the step/dir pulse times? Some VFDs use a 0-10 control voltage range. Some documentation on how to tune mach3 for the spindle motor ought to be provided.
    In the meantime the VBScript solution is working for me.
    1. Problem- mach3 spindle dro not working, spindle speed changing while jogging and running code
      By jasminder in forum Mach Software (ArtSoft software)
      Last Post: 02-23-2011, 01:12 AM
    2. Need Help!- Not getting the right speed of spindle via Mach3
      By Vaffel in forum Phase Converters and VFD
      Last Post: 10-29-2010, 08:30 AM
    3. Spindle speed & Mach3
      By Countryman in forum Mach Wizards, Macros, & Addons
      Last Post: 05-25-2009, 09:53 AM
    4. SX3 spindle speed control with Mach3
      By bbox in forum Benchtop Machines
      Last Post: 07-05-2008, 06:15 PM
    5. Stepper motors are still going at the incorrect speed. Need help with Mach3
      By Apples in forum Mach Software (ArtSoft software)
      Last Post: 12-23-2005, 06:29 PM
