Page 1 of 6 1234 ... LastLast
Results 1 to 12 of 67
Thread: 145 spindle control blew (again)
    Jul 2009
    soooooo my spindle control board blew again. this was a rev a board but at this point im pretty shaky on any board from Sangmutan so im looking for other options particularly using a 3 phase general purpose ac motor with a vfd. in particular a gs1-21po ( GS1-21P0 Products ) coupled to a iron horse 1hp 3 phase motor (MTR-001-3BD36 Products )
    so has anybody done this or know how to implement such a system. or do i have to use a bdlc type motor. if thats the case where can i use this same controller or what. im kinda in no mans land right now as far as knowing what direction to head next so thoughts?
    Feb 2008
    Quote Originally Posted by tjd10684 View Post
    I was in the same boat with the Novakoned junk, and gave up on their lack of support and knowledge. I just installed an AC 3HP 3 phase motor a Teco VFD on our NM-200. It was a bit of messing around mounting the motor and making the pulley but the VFD is very easy to wire up with Mach control.
    Now I just have to change out the control board, drivers ect and then I'll finally have an actual working Novakoned mill, it will still be a piece of junk but it will work for wrough stuff.
    Ray
    Jun 2007
    canada
    when did you get the new drive? khai said they were sending out new ones soon, ill have one shortly. is the one you blew very recent (few weeks)? that would suck if the new ones are still dying.
    xzero is working on a drive that will handle the nm145 motor, but thats a ways a way still unfortunately. the trouble with an AC solution is that most of them will not fit inside the head of the nm145. ive been looking. youll have to adapt it to mount up top.
    as for the inverter, it should come with basic instruction. you need a 0-10V output from the pc to control the speed, and and output to turn it on usually. i *think* the c11g cnc4pc board that novakon uses supports this, but i dont remember the setup. my nm200 had an ac motor and vfd set up already so ive never looked over the wiring.
    Feb 2008
    Quote Originally Posted by ihavenofish View Post
    Yes that could be a minor problem if there's no room. The cover will still fits over the 3HP AC motor I installed on the NM-200. The motor is a WEG 90T Alum frame.
    Yes the C11g works great with most VFD's, I'm using a Teco EC7300. You have the 0-10V signal, one wire for forward on/off and one wire for rev on/off and the grounds, two of which are common.
    Very simple setup, once you have the motor mounted.
    Jul 2009
    @ fish
    no this was a rev a board. i think they sent one they had in stock to shut me up until the new boards got here. i guess im going to have to on them hard again to get a replacement so i can keep working while i figure out the ac drive if for no other reason than to have a backup.
    as far as mounting the motor up top i have no problem with that. it should keep the motor away from coolant even better, cant go too wrong with that right?
    so what everyone is saying is that the control scheme is already there for an industrial 3 phase spindle makes me wonder why they just dont install them from the factory instead of screwing with a supplier that so far has a rocky (at best) track record.
    antother question to those of you with motors installed. what kind of rpm are you getting out of your spindle? i would like to keep my ability to run @ 6k. would a matched set of pullys like a bridgeport be a good investment (maybe just two steps though)
    Jun 2007
    canada
    @ fish
    novakon goofed by speccing the dc motor, but in the past on the 135 and nm070 (sieg based) dc brushless have been perfectly fine, but they arent samutan. mine has no name actually, just "zm-w80-500" (500w). i dont think anyone realised the motors were bad til after everything shipped. i have the first 145, and i didnt notice it wasnt quite right for nearly a month, at which point we swapped both the drive and the motor with no effect. that would have been august or september last year if i recall. note that smithy, sieg, syil and a few others also used them.
    anyhow, for speed, to keep 6k rpm, youll likely need to change the pulleys to a 2:1 ratio. shouldnt bee too big a problem to find pulleys that will fit. and i agree mounting it up top is probably where it should have been in the first place. the internal mounting looks nice and clean, but its a pain in the ass to work with and keep cool.
    Jul 2009
    actually looking at the price difference between 1 hp and 2 hp is about $55 i may just go with the 2 hp. its overkill but i don't think i would have any problem at all with bogging down the motor even with a 2:1 belt ratio. that would also eliminate the spindle power restriction that i have come up against in the past (no more problems spinning 1/2" bits in aluminum) i would then be limited by the steppers and the rigidity of the machine. i may even try a 3:1 ratio for engraving although im not sure how well the spindle bearing would like 10000 rpm or if their even balanced enough to do it.
    Nov 2009
    i spoke with michelle over at smithy(they have come a long way as a company as of recent) and she said they tested the sangmutan drives and were totally unsatisfied with them and they use an american made(i believe) controler that costs more, but she says it has proven much more reliable and improved the low end torque dramatically. the new smithy 1240(nm200) looks and sounds quite nice. she said they kind of just got back into that mill and improving it. i believe she said the bldc drive was from siemens??? its a little more money, but reliability is worth a lot! i am realizing there is a reason novakon has the best priced mills out there.... the smithy rapids at 250ipm and has 6k rpm spindle. best of all, when i could not get novakon to return my emails or calls, i got people on the phone twice in one day at smithy, and only had to hold for the correct person for maybe 1 minute! how nice would that be... when you say change pulleys to 2:1, does that mean the dc motor is only pulling 3k rpm itself? i thought the nm200 with 4k rpm ac motor(like mine) were 1:1?
    Jun 2007
    canada
    Quote Originally Posted by urbanimports02 View Post
    no, i meant for you to use the motor you showed in the 145, you would change the pulleys to a 2:1 ratio. the dc is 6k, so it has a 1:1 setup stock.
    for the 200, mine is 1:1 at 4k with an ac motor. i dont know what theyve done for the replacement ac's on the new version.
    you can also get a tekno spindle motor that runs 12k, 1hp or 2hp. italian made with a canadian inverter. i think the kit runs around $700.
    Jun 2007
    canada
    oh, and for smithy, yeah, im looking at their kit now, and theyve really changed it alot. changed the price alot too of course. its a tricky thing, cause youve got one group wanting everything for pennies, and another who will just skip over to a vmc for reliability. the guy in between who's both rational and budget strapped seems a rare breed. but i think the market might be maturing enough that its time to pour some extra trimmings in the service and quality control, even if the price has to rise to pay for it.
    this motor thing is a disaster, and can really kill a company.
    Jul 2009
    the motor that is in there now (nm-145 and most likely your 200) are 1:1 i think that might be a reason they are unstable their trying to push the motor way too hard and its screwing with the controllers but thats just a theory. so if you look at the links what im trying to do is replace the motor and control board completely with a vfd and 3 phase ac motor rated at 2 hp @ 3600 rpm so a 2:1 ratio would give me ~7200 rpm and a 3:1 would be ~10800 rpm. and that would not be pushing the motor past its 3600 rpm rated max
    Nov 2009
    ok, so when you double the rpm, dont you half the hp and torque? i dont think the spindle would handle a tic over 7200rpm...and yes fish the smithy is a little more money, but includes more on the pc and control side. it is a true turn key machine and is about $2k more then i paid for my machine all in with coolant system, pc installed in cd100 etc. nothing seems masked in there price, or controler for that matter. the smithy comes with a tool box, key board, monitor etc. that stuff all starts to add up. so i guess once i added those items, it puts me at $1500 saved over the smithy, plus shipping would be less from smithy as there is no customs to pay. i guarantee the problems i have had have cost me more then $1500!
  • Page 1 of 6 1234 ... LastLast
    1. Transistor Blew Again!!
      By ranchak in forum Bridgeport and Hardinge Mills
      Last Post: 01-06-2010, 10:20 PM
    2. Need Help!- Blew up my controller! :(
      By Redbeard5 in forum Wood Lathes / Mills
      Last Post: 05-30-2008, 06:05 AM
    3. what blew up?
      By cyclestart in forum Controller & Computer Solutions
      Last Post: 02-27-2008, 07:43 AM
    4. Replies: 0
      Last Post: 10-15-2007, 10:46 PM
    5. Please help I blew up an IC on syil x3
      By Nicodemus in forum Syil Products
      Last Post: 03-14-2007, 02:20 PM
