So i have been running the mill a lot lately cutting aluminum and plastics just like before. its running good the only thing i notice is the z axis kinda grunts at the load of the head when i first start it up. it moves fine and holds tolerances fine but i think im at the limit for the air springs that are on it. so again does anyone know the specs of the air spring in case i have to replace them soon.
LinkBack URL
About LinkBacks
i have not connected the vfd to the output on the board so for now the spindle is under manual control. this was done to keep some of the rf interference out of the control case and i kinda like having separate control of the spindle. i am using a 1.5-1 ratio pulley so i have a range of 450-6000 rpm. while only going slightly over the motor rated speed of 3750 (i go to 4000 rpm to get 6000 on the spindle). the spindle is WAY smoother than it ever was with the dc motor and their is no stopping it. i think if you were to stop the tool now it would tear apart the belt. ill update again once i cut some real metal
