Results 1 to 5 of 5
Thread: Setting zero on Z axis
    Registered fourwheeler's Avatar
    Dec 2006
    What are you guys using to set zero on the Z-Axis?
    Registered cteufert's Avatar
    Jan 2011
    I have been using a corner of an index card under the cutter. I jog down until it just grabs then I know the surface is 0.010" below... the card is 0.008" and the additional 0.002" is the gap that lets the card just move without tearing. (Verified by measuring a step machined in to a block.) I like using the index card because it gives a bit of a cushion should you over run, preventing the material from getting a dimple. It is also nice that a nice round number, 0.010" is the offset.
    Since I installed the touch probe yesterday I will be moving towards using it and the known heights of each tool. This works for me since my tooling is being installed in TTS holders so they always go back in at the same height.
    Visit [URL="http://www.shadowspawnllc.com"]http://www.shadowspawnllc.com[/URL] to see what enhancements I have available for the NM-145.
    UUU
    UUU is offline
    Apr 2010
    UK
    I use a 6mm roller - jog close to the surface, then jog away until the roller will pass under the tool. Then set Z at +6. I prefer this method to the card or shim method as the jogging away is safe from overrun.
    Dec 2009
    I have one of the electrical contact boxes that light up when the tool touches.
    If the box doesn't fit for some reason, I use a 123 block or a gauge block, jogging up .001 until it just slips under the tool.
    Sep 2010
    4" Dial Touch Off
    Might want to check out Edge Technology Products for their 4 In Touch Off Tool. (See attached Picture).
    While its advertized for Z touch off only, I use it exclusively for X,Y & Z touchoff.
    For my money its:
    1. Quick
    2. Safe
    3. Accurate
    Gave up using paper , feeler gauges etc.
    John
    Attached Thumbnails Attached Thumbnails Setting zero on Z axis-4_dial_gauge_block.jpg
    1. 4-axis mill post and a-axis datum setting
      By inflateable in forum EdgeCam
      Last Post: 02-09-2011, 03:35 AM
    2. Newbie- Best way of setting Y and Z = 0 on 4th axis job?
      By goor in forum General Metal Working Machines
      Last Post: 07-05-2010, 12:15 PM
    3. Help setting up 4th axis
      By daanmuller in forum Taig Mills & Lathes
      Last Post: 04-03-2009, 05:55 AM
    4. Need help setting up axis...
      By bradtal in forum Joes CNC Model 2006
      Last Post: 01-28-2008, 10:02 AM
    5. help with setting z axis
      By shamus13 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 12-11-2007, 10:36 AM
