Results 1 to 5 of 5
Thread: Visual Mill 6.0
    Feb 2010
    Visual Mill 6.0
    I am having trouble using Visual Mill 6.0 to create a G code file for the attached STL file. Is it possible to create a 3-axis G code file using the STL file I have created?
    I would appreciate someone's help in using Visual Mill 6.0 to create a 3-axis G code file to machine this part.
    Attached Files Attached Files
    *Registered User*
    Aug 2004
    T
    What did you design the part in?
    And what exactly is the problem you're having?
    The file is not importing correctly for me in VM, Solidworks, or Rhino. If you can save it in a different format it may help.
    Feb 2010
    Thanks to help from CNC zone members I can now use Visual Mill 6.0 to create a useable G code file.
    I want to thanks everyone for their help!
    Dec 2006
    What was the solution in the end?
    Feb 2010
    webgeek,
    The solution involved learning how to properly orient the part geometry. In other words, creating two G code programs -- one machining the part from the top, then flipping the part over to machine the part from the bottom.
    1. Visual mill
      By merritt boyd in forum Mach Software (ArtSoft software)
      Last Post: 06-30-2007, 06:24 PM
    2. Need help with VISUAL MILL
      By replicapro in forum Visual Mill
      Last Post: 06-18-2006, 11:06 AM
    3. ONE CNC or Visual Mill ???
      By ninewgt in forum OneCNC
      Last Post: 07-06-2005, 10:56 PM
    4. Visual Mill 5.0
      By ninewgt in forum Visual Mill
      Last Post: 02-06-2004, 11:00 AM
