Results 1 to 6 of 6
Thread: T-Slot Spacing
    Dec 2006
    T-Slot Spacing
    Long story but I can't measure it myself - I need to know the t-slot spacing center-to-center on the NM-200. Anyone know it? It's not in the manual and I can't get at my machine to measure. Thanks!
    -Mike
    Feb 2010
    T-slot Spacing on NM-200 Pro Series 2 CNC Mill
    Four slots 2 3/8" center to center.
    Jun 2006
    Are you sure it isn't 60 mm center-to-center? If these mills are made in China they are probably made to metric specs.
    Feb 2010
    I measured the T-slot spacing at 2 3/8" and 60.21mm. The width of T-slot was measured at 5/8" and 15.98mm. The Novakon user manual shows the T-slot specifications as 5/8" and 15.88mm and the table size as 40" x 12" (1016mm x 304.80mm). The manual does not show the T-slot spacing.
    Registered Hirudin's Avatar
    Jun 2008
    I just measured mine with my cheap calipers. One of the slots was 15.84 mm and one of the lands was 44.45 mm. So I guess that makes the center to center distance 60.29 mm or ~2.374 in. If you need it closer than that I can't help you.
    *Registered User*
    Aug 2004
    T
    If you're wanting to know for fixture manufacture don't drill holes in the "precise" t-slot locations for locating the fixture. It's better to slot or drill oversized to allow for some play, and drill & ream the table (yes, the table) for locating pins. Fix the location of the locating pin holes carefully on the bottom of the fixture or vise and voila you've got a perfectly repeatable fixture location in the WCS, at least as accurate as the homing switches allow. It also take all of 30 seconds to swap fixtures.
    1. T-slot spacing
      By dougtyler in forum Tormach Personal CNC Mill
      Last Post: 10-27-2010, 07:55 AM
    2. g47 font spacing ?
      By panaceabea in forum Haas Mills
      Last Post: 04-22-2009, 06:10 PM
    3. cutting a slot with a t-slot cutter
      By cncuser1 in forum Mastercam
      Last Post: 09-09-2008, 10:02 PM
    4. Help with equal spacing
      By MegaMoog in forum EdgeCam
      Last Post: 06-03-2007, 09:45 AM
    5. Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill?
      By weaston in forum General Metalwork Discussion
      Last Post: 04-11-2007, 10:00 PM
