On my NM135, the drain hole would similarly clog. The solution was to put a dome-shaped sieve over the hole, with the dome oriented up. I used the sieve (basket) from http://www.novakon.net/wpimages/wp5083f61a_05.jpg. The sieve just sits loose. It will stay unclogged for a few hours of milling, after which I pick it up and give it a whack over the garbage can to clean it off.
LinkBack URL
About LinkBacks
