Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Deseperate Help Needed: NM-200 Spindle + Coolant Issue
  1. #13
    *Registered User*
    Aug 2004
    T
    Quote Originally Posted by webgeek View Post
    Ha ha, I blew it Joe. I saw your last message but it didn't sink in. When I copied your settings my spindle started to spin backwards and I never noticed. Several ruined bits and some metal later I posted in the metalworking forum and some people pointed it out to me. I've never even tried to run my machine backwards so to be honest, I didn't even know it could. I should have noticed it - my bad. At least we know, the spindle relay is very important
    Sadly, this means I still have an issue with pre-configured spindle/flood coolant relays from Novakon. I'll do more looking in the morning. Thanks!
    -Mike
    Try configuring the outputs as shown above (note output #s in spindle settings for the spindle and coolant, and the ports and pins for the speced outputs in ports and pins).
  2. #14
    Dec 2006
    I'm going to eat some crow here. I'm updating this thread for completeness and accuracy. Long story short, the coolant relay came disabled on my mill. Enabling the coolant relay caused my g-code programs to stop working properly - the spindle would never turn on and engage though the coolant would. This got me down the track that they were tied together in a wierd way.
    Long story short, the problem was actually in the post-processor for Visual Mill (I THINK!) where if the coolant was enabled for the tool but the spindle speed was left at the default or some such the spindle speed in the output would be wrong (it would be blank IIRC.) I didn't try and research the exact cause once I got it worked out.
    The end solution was just making sure my tool library had the spindle speed set for every tool along with coolant for every tool. Instantly it all worked perfectly. The key was the suggestions to run the M codes by hand - they all worked fine as they should. That's when I realized something else was at fault.
    Anyways, it's all good now and I'm still at the point where my Novakon NM-200 came from the factory perfectly set up. Simple as that.
    -Mike
  1. Newbie- Need Help with Coolant Issue!
    By Chaps in forum General Metalwork Discussion
    Last Post: 03-22-2010, 10:34 AM
  2. Help with Flood Coolant / when to change? & possible health issue?
    By Rich05 in forum General Metalwork Discussion
    Last Post: 03-18-2009, 09:42 AM
  3. X3 Spindle Issue?
    By chns in forum Benchtop Machines
    Last Post: 11-26-2008, 06:58 PM
  4. Milling coolant needed
    By bob1112 in forum General Metalwork Discussion
    Last Post: 04-09-2007, 07:32 PM
  5. School In Deseperate Help for CNC PLasma
    By MatDaddy in forum General Waterjet
    Last Post: 05-08-2006, 10:42 AM
